Old 03-27-2009, 09:39 AM
seanreit is on a distinguished road
I need a new tailstock for my Harbor 9x20 lathe
anyone know where I can get one?
Old 03-28-2009, 07:39 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi Sean!
Parts breakdown on page 38. You will need to ask for a tailstock complete. Or you may have to buy all the parts separately.
http://www.harborfreight.com/manuals...5999/45861.pdf
Harbor Freight Parts Warehouse: 1-800-444-3353
It will probably take about 7 weeks to arrive from China.
CR.
Old 03-28-2009, 07:49 AM
blackbeard52 is on a distinguished road
Check here for a lot of info on that model.. http://www.mini-lathe.com/Mini_lathe...sions_9x20.htm it appears that there is alot of brands that use the same lathe. so parts can be obtained from many sources even in the US
Bob
Old 03-28-2009, 07:53 AM
BigMike4u is on a distinguished road
These guys should be able to fix you up.
http://www.littlemachineshop.com/default.php
I live in my own world, but that's ok they know me here.
Old 03-28-2009, 07:56 AM
Actually Little Machine shop only goes to 7x and 8x
Old 03-28-2009, 08:10 AM
Thanks for the suggestions, I called HF, no dice for 8 weeks. Darn, was hoping to get one sooner than that. I messed mine up pretty badly drilling bigger than I should have faster than I should have. Messed up the threads internally, and now it works but it takes herculean strength to move it. Wish I could find someone with it in stock....
Old 03-28-2009, 08:15 AM
If its only the threaded portion of the tailstock... you could have the brass insert remade locally or make it yourself on the lathe... replace the threaded rod with a metric all thread rod.....as I recall it is a standard thread not acme... even if it is acme...order it from McMaster Carr and I think they even have a brass nut you could turn down for the insert... Problem solved...
Bob
Old 03-28-2009, 08:36 AM
ZipSnipe is on a distinguished road
Or just disassemble it and clean up the threads, sometimes you can just use a knife file or clean 'em up the lathe.
I would get the tailstock from Harbor Freight, my motor went out and Harbor freight was way cheaper than Grizzly
Old 03-28-2009, 09:05 AM
The Grizzly 9 x 19 MAY use the same tailstock.
http://grizzly.com/products/9-x-19-Bench-Lathe/G4000
Page 50:
http://grizzly.com/images/manuals/g4000_m.pdf
It will cost more from Grizzly because they DO have parts in stock.
1-800-523-4777
CR.
Capacitor for my 9x20 lathe? ZipSnipe General Electronics Discussion 2 02-06-2009 06:41 PM
Will this control RPM on a HF 9x20 lathe? seanreit General Metalwork Discussion 4 01-06-2009 01:22 PM
HF 9x20, can the tailstock be converted CNC? Done XY already. seanreit Mini Lathe 9 12-25-2008 07:03 AM
Cheap 9x20 lathe cnczoner General Metal Working Machines 0 09-26-2008 08:50 PM
9x20 Lathe question ccm General Metal Working Machines 13 09-25-2003 05:52 PM
