Old 03-25-2009, 10:04 AM
bobrob is on a distinguished road
Question question about hard turning with ceramic inserts
DO YOU USE COOLANT ? OR RUN DRY WITH OUT COOLANT ..? OI am tkaing off arox .015 per pass. surface feed of 300 spindle speed of around 400 rpm .
Old 04-06-2009, 10:04 PM
pvellenga is on a distinguished road
Run it dry
Run it dry for best results. The coolant will cause thermal shock and weaken your insert.
Old 04-06-2009, 10:29 PM
HuFlungDung's Avatar
Moderator
Yup, dry always. The chip should be red hot, that is when you know you are going fast enough. With that being said, I don't like to overshoot the 'just red' condition too far, as this can shorten tool life unnecessarily. Check that your ceramics are rated to machine the type of material in the condition you are cutting, as a mismatch rapidly leads to tool failure.
Old 04-11-2009, 02:55 AM
Guldberg is on a distinguished road
IMO you can easily crank it up. I just turned down a piece of tool steel (not hardend though) 80->20mm. 640rpm, 1.5mm on diameter per pass. I have a load of theses inserts, so wear didnt matter, but i didnt notice any anyway. Just watch out, the chips are razor sharp and burning hot (pretty blue). One landed on my neck causing a nasty nasty burn!
And as already pointed out. Without coolant. You want the temperature to be steady
Need Help!- Hard Part turning Vaibhav.Shelke Daewoo/Doosan 10 10-08-2009 09:11 PM
Questions about Ceramic Inserts... Crashmaster General Metalwork Discussion 18 06-11-2007 05:42 AM
Hard turning Steve@Reliance General Material Machining Solutions 23 07-31-2006 12:33 AM
hard turning carbide bonz General Metalwork Discussion 5 01-21-2005 11:24 AM
Ceramic Inserts Turbine CNCzone Club House 2 09-24-2003 09:23 PM
