Old 03-24-2009, 08:18 AM
sava is on a distinguished road
Deckel FP3A
Hi there i'm new to this. I'm a machinist of 9 years and lookin atsetting up my own little M/C shop from home here in Perth WA, I've just found a Deckel uni mill that i'm very keen on purchasing but the controller (cnc2102) will only work in manual mode which is fine for wat i want to do but i really would like to fix it. Does anyone out there have any experience with these mc's and could point me in the right direction. Cheers Sava
Old 03-24-2009, 11:26 AM
The Blight's Avatar
The Blight is on a distinguished road
I believe thats the same machine we have at work. I will check if the controller is the same and if it is, I might be able to help. How much are you going to pay for it?
Does it give any error messages when starting up?
Old 03-26-2009, 09:38 AM
He's asking for $8000 aus. I'm not sure of the code when it starts up but instead of coming up with numbers when you set xyz zero it has letters? I will try and find out more info onthis m/c
Old 03-26-2009, 11:27 AM
The Blight's Avatar
When setting XYZ as zero, I believe you have to enter some G-Code first. Our machine has a preset button that brings up a couple G-Codes so that you can zero the axis.
Old 06-14-2011, 01:35 PM
dago_duck73 is on a distinguished road
i think i have the same problem. The Fpa works fine in manuel mode but in mode 9 there i can program. Do you know what the number 83 down at the right site of the display means?
Old 06-14-2011, 04:25 PM
underthetire is on a distinguished road
We just dumped several Deckels. people got them for about 1K each. Rip that POS control off and put a mach 3 on it.
Need Help!- deckel maho dmu 50 t gunz Deckel, Maho, Aciera, Abene Mills 8 12-01-2010 01:17 PM
What can you do with a DECKEL SO grinder? Jim Estes Toolgrinding & Toolgrinding Machines 2 02-02-2009 06:20 PM
Deckel GNC-1 Dirkos Deckel, Maho, Aciera, Abene Mills 1 09-02-2008 06:08 AM
Deckel FP1 (CNC?) stephaan Deckel, Maho, Aciera, Abene Mills 2 02-04-2008 09:52 AM
Deckel DMU 50V andyt Deckel, Maho, Aciera, Abene Mills 12 05-25-2006 03:42 AM
