Old 03-19-2009, 04:33 PM
integerspin is on a distinguished road
showa oil pump?
I was cleaning a showa YMAS pump, only partially stripped and cleaned it so far.
Doesn't look like it should work! the piston/plunger has an output one way valve but no input valve?
Does anyone have a manual for a machine that has a showa pump, I can't find one on the internet.
showa way lube pump will-tek Fadal 0 11-19-2008 09:44 PM
OK, I've got my vacuum pump. Now what do I do with it? DougO Work Fixtures and Hold-Down Solutions 0 07-09-2008 02:35 AM
Need Help!- coolant pump JACKSMACHINE Fadal 0 05-22-2008 03:13 PM
TM2 Coolant pump Peter Gibbs Haas Mills 4 05-03-2008 12:11 PM
Coolant Pump Smackre Mechanical Calculations/Engineering Design 7 06-29-2007 01:16 PM
