Old 03-16-2009, 10:50 AM
tricmachine is on a distinguished road
Throwing tools! NEED HELP!
Hi, I have a Mazak Integrex 200SY with the tool magazine. All morning when the tool arm goes to switch the tool out it lets go of it half way and throws it out the back of the machine. This has happened before when it was really cold but I figured it just needed to warm up. But its 70 degrees out today so I don't know what's going on.
Old 03-16-2009, 11:44 AM
eSilviu is on a distinguished road
what did you did?!
I think you make her mad ...
but I don't think a flower will change anything!
Old 03-16-2009, 11:54 AM
laszlozoltan is on a distinguished road
kinda funny in a dumb way; but a serious problem too. We experienced a bit of that at my old place. Things to check, adequate hydralic fluid, air hose not leaking, position sensors get gummed up and need to be cleaned.
Old 03-16-2009, 11:57 AM
Originally Posted by laszlozoltan View Post
kinda funny in a dumb way; .
thank you
Old 03-16-2009, 01:02 PM
CNCRebuilder is on a distinguished road
Tool Tossing
Tool tossing hard on sheet metal and tooling
Is it doing it on both pockets?
Heavy and light tools?
1. Check the ATC arm. On the arm where the tool locates there are plungers that are spring loaded. Sometimes the springs break or get gumed up. Also the plunger end will wear over time. On some there are an additional locator plate for the tool keyway.
2. You can find the air or hyd valve that controls the arm, turn down the flow so the arm moves slower see if you can see why it is tossing the tools.
3. Check location of all axis, to ensure that machine is at proper pos.
Good Luck.
Old 03-16-2009, 03:19 PM
mazakguru is on a distinguished road
Isn't this a servo driven arm?
Bring your own tools or does your company supply tools? ZipSnipe CNCzone Club House 10 02-04-2011 07:06 PM
Just throwing this out there (tuning setup) justCNCit Linear and Rotary Motion 0 09-28-2008 08:27 PM
Em throwing off a big burr Vern Smith Haas Mills 12 01-23-2008 04:38 PM
tool changer sticking and throwing tools out jetski HURCO 2 01-21-2008 03:27 PM
Tools lilguy General Metal Working Machines 1 10-14-2007 10:14 PM
