Old 03-15-2009, 05:10 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
1986 qt10 getting rid of hi/low unit and replacing spindle drive
Ok so I want to rid our old iron of its hi/low system and add a different spindle drive becasue I do not trust the oem hi/low system. The questions is can we simply add a different spindle drive and run the motor directly to the spindle with belts?
I know the mtor would have to spin faster but would this really be a problem. Lets say we have a 3500rpm max and we start with a 10hp spindle motor can we add in a 15hp drive and run that motor like I am describing or am I nuts?
We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
Need Help!- okuma lb15 spindle drive unit TTT Okuma 2 02-03-2011 08:49 AM
Need Help!- MITSUBISHI SPINDLE DRIVE UNIT MDS-A-SPJ-75 chagin General Metalwork Discussion 0 08-09-2008 12:19 AM
Need Help!- Replacing the FNC-5 control unit ltek General CNC (Mill and Lathe) Control Software (NC) 1 07-18-2008 02:31 AM
Need Help!- okuma LB15 spindle drive unit TTT Okuma 1 03-17-2008 06:51 AM
Replacing a HF unit amron Welding, Brazing, Soldering, Sealing 2 04-28-2007 08:57 PM
