Old 03-08-2009, 04:06 PM
twistedturner is on a distinguished road
Mazak SQT 18 205 alarm
We have been having this problem on and off for 4 months now.This is a mazak SQT 18M with live tooling.We get the 205 (milling controller malfunction)even when there is no milling op. in the progam.There is a small gear(2 inch dia.) that is engaged by a larger gear on the index drive motor which causes the turrent to index.These 2 gears are normally engaged during operation of the machine and disengage during live tooling operation.If the small gear is not alinged just perfect, you will start to get a load showing on the mill spindle load meter(even when not useing live tooling).The gear is held by 2 taper lock bushing,...we have replaced the gear and both taper lock bushing but still have problems with the gear working itself out of alignment and eventually the load meter will be high enough that we get the 205 alarm.When we realign the gear we have varying results, sometimes it will last 6 weeks and other time it will last less than a day.Is there a trick to getting these taper lock bushing to hold the gear tighter?
Mazak T2 alarm codes pa2262 Mazak, Mitsubishi, Mazatrol 2 01-28-2009 07:53 AM
Mazak H-500 Alarm newguy81 Mazak, Mitsubishi, Mazatrol 4 09-27-2007 09:33 PM
Mazak FAN alarm leito1489 Mazak, Mitsubishi, Mazatrol 2 09-08-2007 08:22 PM
Mazak alarm code 323. Need help please. RMagnusson Mazak, Mitsubishi, Mazatrol 8 02-20-2006 03:05 PM
Mazak L Alarm SFA Machine Problems, Solutions , Wireless DNC, serial port 2 05-26-2005 12:52 AM
