Old 03-07-2009, 05:00 PM
slashmaster is on a distinguished road
Is there a such cnc machine that will bend sheet metal any way you want?
I know there is a such thing as a cnc tubing bender. I was just wondering if there is a such thing as a cnc machine that can fold a piece of sheet metal any way you want? Like maybe make a fender? Or is this only possible by stamping?
Old 03-07-2009, 08:48 PM
Cartierusm is on a distinguished road
No, I don't think so; there are cnc sheet benders but they only bend angles. That would be cool, but not possible.
Old 03-07-2009, 08:57 PM
austin.mn is on a distinguished road
Actually, there are several computer controlled sheet benders out there. I remember watch a video at one point that was pretty impressive. That being said though, I don't think that you are going to bend a sheet metal fender with a press brake even if it is controlled with a computer. On the other hand, I did read about laser bending. They took and heated a sheet of metal up specificly here and there and wallah 3D sheet metal bending.
Old 03-08-2009, 01:34 AM
One of Many is on a distinguished road
No such thing as a CNC fender bender if the part has a 3D profiled surface. That would take a stamping press, which could still be CNC controlled.
Check out Youtube. They have all kinds of robotic industrial equipment in action.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 03-08-2009, 03:36 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
Motorcycle fenders? Or car fenders?
If you want to make motorcycle fenders, you can make a "slip roll" with round dies and form motorcycle fenders in halfs and weld them together.
Usually motorcycle fenders are either hand rolled in dies as mentioned or stamped in halfes and welded together.
Car fenders are just stamped out using multiple stamps, couldn't do that on a shop press though.
There is a shop not far from me that makes replacement fenders for RollsRoyce restorations, they use an english wheel and they didn't say how long it takes, A LONG TIME I'm sure.
Old 03-08-2009, 10:50 PM
PixMan is on a distinguished road
Nothing out there that I know of yet, but the first guy to come up with a CNC-controlled version of a english wheel will be a very wealthy man.
Old 03-09-2009, 05:02 PM
zephyr9900's Avatar
zephyr9900 is on a distinguished road
It's been done, kind of. OCAS has developed a machine that uses a stationary "spindle" to progressively form metal over a CNC'ed wood or urethane buck. I have a PDF and video from them from 2006, both of which are too large to upload here (8MB and 14MB)
edit: This is a link to a much smaller video that shows the technique briefly.
The machine looks very heavy-duty and expensive.
Randy
Old 03-10-2009, 12:07 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
There is a relatively new process called "incremental sheet metal forming" that is done on a CNC mill:
http://www.journalamme.org/papers_am...a1f4372676ee49
Here is a really cool video of sheet metal forming:
It would take quite a machine to make an automobile fender, but a hood scoop, wheel flare, or something similar should be doable on a reasonably sized machine.
Cheers,
BW
Old 03-10-2009, 01:17 AM
Good call on the video! Kind of a diffrent twist on metal spinning, huh? Any more details on the process? I'm guessing there is a little more to it than a 3 axis mill and a chunk of sheetmetal....
Old 03-10-2009, 01:25 AM
Randy
I'm confused. This process looks like 3d printing, but they said "metal". The video Bob posted looked like a 3d metal spinning, just in reverse of what I know of metal spinning, or was it?
I guess I'm stuck in the stone age. I don't work for a high-tech company anymore, so I don't get to go to customers and see any of the new technology, equiptment and processes like I used to... sucks! That's the one thing that I do miss... That and paid vacations,(the kind where you say **** work for 3 weeks) miss those too!
  #11   Ban this user!
Old 03-10-2009, 11:11 AM
zephyr9900's Avatar
The video Bob showed is the same technique as the OCAS video I linked to, except the spindle is turning in his case.
In both cases, they first CNC machine a buck (male form) made of wood or plastic. The sheet of metal is clamped over the buck, and the spindle pushes the metal over the buck in an operation like waterline machining. Notice the lubricant, which I assume is the same as used in deep-draw stamping.
It's a lot like vacuum forming, but done mechanically instead of with heat.
Randy
  #12   Ban this user!
Old 03-10-2009, 11:53 AM
Ok, So who is going to be the first on the Zone to do it and teach us all?
There is definitely a few projects that I would like to do with that technique, but I will probably be short on time for the next month or two. It does look like a guy with a standard three axis machine should be able to do it though.
Sheet Metal Patterns phatfred8 Solidworks 15 05-21-2009 02:34 PM
Need AL or Steel bending die to bend sheet metal firearm receiver mike_r Employment Opportunity 1 06-11-2007 08:03 AM
amount of bend in metal myinisjap Mechanical Calculations/Engineering Design 3 02-18-2007 08:52 AM
Tog Gun Construction From Sheet Metal username132 Europe Club House 0 01-15-2007 07:11 AM
RFQ for Sheet Metal Work Rob_M. Employment Opportunity 6 02-13-2006 01:14 PM
