Old 12-27-2004, 06:01 AM
pigifly is on a distinguished road
Advice required for my next milling machine.
Hi all,
after have successfully used the proxxon bfx40 setup for a while, I have understood that ( to speed-up jobs ) I need a bigger setup.
Actually I have seen a couple of machines that seems to be right, but I need your advices on which would be better, just to avoid a bad choice.
The two products are :
http://www.hbm-maschinen.de/output/c...r.aspx?cid=166
and
http://www.harborfreight.com/cpi/cta...emnumber=44991
( but the european version, that is metric units ).
For the first one there is no Z microfeeder, but on the main site there is a project for adding such feature, and is priceless. The motor power is 500W
For the 2nd one , there is the microfeeder, but it cost almost two time then the first one, and the motor is 350W.
Anyone has never tried the first one ( I know a lot of you has the second ) and have comments ?
What do you think will be the best choice ?
T.I.A.
Pigi
Old 12-27-2004, 07:00 AM
*Registered*
ESjaavik is on a distinguished road
If you can read German, here is a conversion of HBM 16 going on:
http://5128.rapidforum.com/topic=115...earch=HBM%2016
If you don't understand German, the pictures are the universal language.
Old 12-27-2004, 03:58 PM
Nice shots there, ESjaavik, but I can't read german so I can't understand if the machine is good or not.
I don't think I will CNC it, for the moment, only speed up some of my jobs ( more power than my actually setup ) so I was asking for info on precision and backlash and all of those things.
Thanks anyway
Pigi
Maho MH600E Milling machine questions??? marx911 General Metal Working Machines 4 01-23-2009 12:51 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
which milling machine to start out with? cowanrg Benchtop Machines 7 01-18-2005 04:34 PM
Starting first machine, looking for advice. nuplowboy DIY-CNC Router Table Machines 2 01-17-2005 10:57 PM
