Old 03-04-2009, 11:25 PM
integerspin is on a distinguished road
cleaning lubrication system metering valves
I have the showa PSS metering units. The metering units were in need of a clean.
I was told that they should just be replaced, one price I got was around 20 quid[pounds] each and there are in excess of 25 of them.
I wondered if any one had cleaned them successfuly. I stripped them and pumped filtered petrol through the filter backwards. It took several goes for a resonable stream to flow through the filter in the correct direction. But the filter is probably still full of the crud. I was tempted to buy one, so I could cut the filter open on one of my old ones and see what it looks like.
Old 03-05-2009, 02:05 PM
BillTodd is on a distinguished road
I have four on my Hardinge lathe (different manufacturer - Bijur FSA0 & FSA1), I broke one of the small collet/spacers (like your brass one above, except mine was hardened steel and cracked). I fully understand your use of bad words
Mine have a small felt filter on top of a fine gause. I teased the felt out with a needle cleaned it and replaced it. However, I could not get anything to flow through the things.
A guy on the practicle mechinist site said they are standard parts in the US (i.e. a few dollars). He also suggested that they are pressure sensitve, so that nothing much will flow until the pressure is fairly high (I tried air @ 80psi!). I guess he's right; if the pin is tapered, with enough pressure, it would move and allow a small controlled flow of oil.
If you find a low cost supplier please post here (I will do the same).
Bill
Bill
Old 03-05-2009, 02:24 PM
Found a US supplier with Uk distro - no Idea of cost yet (have sent email)
http://devcocorp.com/american/bijurmeters.htmhttp://devcocorp.com/american/bijurmeters.htm
[edit] $21.05 each plus shipping minimum order 10off
[edit2] Found a US ebay supplier Central Suplus he has Bijur metering units for £3.51 each but UPS shipping is £21 ! (OK is you need 25, not so good if you need just one )
[edit3] Central surplus have kindly agreed to ship a few of these first class for ~£12 so that's me sorted
If you check the number on your PSS device it should correspond to the flow rate of the Bijur units. The three letter code signifies threads etc. (see here: http://www.bijurdelimon.com/productd...nits_DS(4).pdf) for details.
Bill
Question about valves Adaware I.C. Engines 6 02-21-2009 03:30 PM
Series 1 Z Axis Lube Metering Unit kewl_cat Bridgeport and Hardinge Mills 0 01-30-2009 11:14 AM
Metering/Dosing pump pds Mechanical Calculations/Engineering Design 28 12-03-2008 02:31 PM
Anybody setup a lubrication system on their mill? phantomcow2 Benchtop Machines 3 02-11-2007 09:30 AM
valves for oxy/gas torch? redneck79 CNC Plasma and Waterjet Machines 1 10-11-2006 10:26 PM
