Old 03-04-2009, 12:31 AM
PhoenixMetal is on a distinguished road
Optimizing milling feedrates and speeds - watching the spindle load meter
I am trying to optimize the speeds and feedrates for the tools in my Vertical Machining Center to increase my cutting speeds, and I have some questions...
The spindle motor load meter on my machine control is reading around 25% while cutting. I assume that means I am free to push the machine harder.
So what parameters should I change? RPM or Feedrate?
Also, what is a healthy spindle load percentage to run the machine at? Should I aim to keep it as close to 100% as possible, or is it better for the machine to keep it more in the 50 - 75% range?
Thanks!
Old 03-05-2009, 07:41 PM
masonbcaldwell4's Avatar
masonbcaldwell4 is on a distinguished road
Call me crazy, but I pay little attention to the load meter except on the first run, just to make sure I'm not overly taxing the machine... that being said, I keep upping feeds and speeds until it starts to chatter, then back off just a hair. That's about as effecient as I can get with the crappy tooling we have, and our management won't invest in the good stuff. shoot, it's hard enuff just to get ahold of a solic Carb. mill, much less a coated one. hope this helps,
Mason
Old 03-05-2009, 07:57 PM
There should be no problem running a spindle at 100% load all the time but of course this will never happen. Even peaking above 100% for a few minutes is okay on most machines.
Having said that I think before worrying about your spindle load look at your program speeds, feed and depth of cut. What material are you running and what is the cutter size. For instance with 6061 and a 5/8" two flute carbide designed for aluminum you can run 10,000rpm, full width, 0.5" deep at 0.005" per tooth which translates to 100 inches per minute; if you have enough power.
You find out if you have enough power by programming conditions that you should be able to reach based on the material and cutter then back off on the overrides for the first cuts. If the machine seems happy and the spindle is okay start moving the speed and feed up. After a bit of experience you start getting some idea of how far you can push things.
LB-15 Spindle load meter nlh Okuma 2 10-11-2008 05:55 PM
Feedrates spindle speeds and tooling Patrick_H WoodWorking 5 02-13-2007 10:17 AM
TAIG spindle speeds and a load meter question Smertrios Taig Mills & Lathes 2 04-26-2006 04:34 PM
Spindle load meter ? Ken_Shea Haas Mills 1 10-10-2004 10:21 PM
