Old 12-24-2004, 12:36 AM
*Registered User*
coolman is on a distinguished road
Ball Screws & Nut Advice
Hello,
I am building a metal mill using 3" x 3" x 0.25" mild steel square tubing. The x-axis (gantry) measures 62" across. I need to buy some Ball Screws & Nuts. This means I need to buy a 62" Ball Screw. My question is what diameter size Ball Screws should I get such that the 62" ball screw does not bend? The diameter choices are 5/8", 3/4", or 1". Of course the bigger the diameter the more expensive. Backlash and or bad stuff happens when the screw bends or whips. Is there any other advice that I need to determine the size of the ball screws I need? Also, what is the difference between a round or square ball nut? The square one is cheaper.
I tried uploading a picture but the file is too big. Does anyone know of a program to resize a jpeg file?
Thanks,
Old 12-24-2004, 08:29 AM
ger21's Avatar
http://www.nookind.com/ball/BallCalculators.cfm
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Revolutionary Linear Drive System allanconway2 Polls 21 05-03-2009 08:27 PM
Which Ball Screws to use? Willyb Linear and Rotary Motion 4 01-19-2005 08:49 PM
Single Nut Ball Screws Cold Fusion DIY-CNC Router Table Machines 10 03-24-2004 09:41 PM
Z-Axis and Ball Screws samualt DIY-CNC Router Table Machines 15 01-10-2004 02:10 PM
