Old 03-01-2009, 04:51 PM
cvriv.charles is on a distinguished road
Converting a non cnc lathe into a cnc lathe?!?!
Hi. I was wondering how possible it is to turn a non cnc lathe into a cnc lathe? I was thinking about purchasing a nice lathe. The lathe I need is large, about 5300lbs. I would need to convert this size lathe into a cnc lathe. How much trouble would this be?
I need this lathe to produce prototypes and even products in somewhat small quantities. I need a lathe this big because I need a fairly large spindle bore because I need to spin large diameter acrylic tubes. I need to cut internal threads for these large tubes. So I figured I would get a large enough lathe and convert it. Again,... how painful would that be?
Thanks in advance.
Old 03-02-2009, 10:05 AM
salzburg is on a distinguished road
If you can get or have all 2008 copys of the homeshop machinist
magazine by village press you will find guy by the name of freistad
describing the whole process. great description.
Old 03-02-2009, 11:06 AM
deakin85 is on a distinguished road
just wondering why you would convert a coventional lathe to cnc if it's for prototypes or small quantity?....... manual lathes are ideal for making prototypes.
Old 03-02-2009, 11:22 AM
Al_The_Man's Avatar
One of the down sides is you have to do a mechanical conversion as well as CNC control.
I would not recommend anything but precision ground ball screws, you might get away with rolled, but you should definitely get the preloaded ball nut as without, rolled can have quite a bit of backlash.
If you buy a used CNC that size & needs a new controller, you get ballscrews, spindle motor and encoder etc. and possibly reuse servo's
Old 03-02-2009, 12:48 PM
One of Many is on a distinguished road
Considering the cost of the lathe and tons more cash, blood, sweat and tears converting it. Along with very low top RPM for bigger thru-bore lathes. You might look into one of the larger used Bridgeport EZ-Path or SWI toolroom lathes.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 06-08-2010, 04:18 AM
Gaurav is on a distinguished road
Has anyone found the copies of the homeshop machinist mentioned above??
It would be of great help if you can forward them
My ID is gaurav2701@gmail.com
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 03:27 AM
Converting a Grizzley Lathe to CNC is it worth it? Rich05 General Metalwork Discussion 2 07-11-2008 10:51 AM
New Machine Build- Milltronics mill- converting to verticle lathe dmelacom Vertical Mill, Lathe Project Log 1 03-10-2008 06:05 AM
Converting manual lathe to CNC pwpeterson General Metal Working Machines 4 11-22-2007 10:26 AM
Converting a lathe to CNC Odie Wan General Metal Working Machines 1 04-18-2007 09:37 PM
