Old 02-27-2009, 01:38 PM
ligito is on a distinguished road
Milling Help
I have a Jet JMD-18 Mill/Drill, with a table feed motor.
There is a lot of slack when I change directions with either manual, or motor.
It has to take up the slack before it will change direction-a lot of slack.
How can I mount a piece of 1/8 inch aluminum in my vise, so I can mill around the edges?
I want to mill a 1/16 round, or end mill a 1/8 recess.
Currently, I have to mount it flush in the vise and need to know how to elevate it, so I can cut around the edges.
Old 02-27-2009, 04:30 PM
The slack is called backlash and low cost machines often have a lot.
You always have to feed the work into the cutter so the cutting action is pushing the part against the direction you are feeding; this is called conventional milling. Should you try feeding so the cutter action is trying to pull the part into the cutter it will because of the backlash and your cutter will probably break.
You may find there is an adjustment on the nut for the feed screws that allows backlash adjustment.
With those low cost machines sometimes it is worthwhile taking them apart and cleaning an deburring everything and when re-assembling snug all the adjustment up nicely. Some people suggest using lapping compound to make things move smoothly but I do not recommend this; just file nice little chamfers on all sharp edges and possibly polish rough surface smooth with Scotchbrite abrasive, this removes sharps edges but does not take of appreciable metal.
Regarding milling all round something in the vise this of course is impossible because the vise has to grip somewhere on the part. You have to put packing under you part so it is only gripped by a small amount such as 0.05" then you can carefully machine anywhere on the exposed part to a depth of about 0.70" without touching your vise jaws. You can buy parallels designed for this but packing your own packing strips is less expensive.
I am guessing you are new to this? Just keep asking questions and if you don't understand the answers say so and ask more questions. If you keep asking the same question for week after week we will get frustrated with you and let you know but overall you will get tons of assistance here.
Milling with bottom vs milling with side? REVCAM_Bob CNCzone Club House 13 06-30-2008 09:23 AM
Newbie- V21 2d milling help bseibenick BobCad-Cam 2 04-28-2008 09:45 PM
3D milling with TNC-155 praest General Metal Working Machines 2 10-01-2007 02:01 AM
3D IH Milling wildcat Industrial Hobbies (Support forum) 30 03-09-2007 05:32 PM
Need help for CNC milling set up a00509265 Machine Problems, Solutions , Wireless DNC, serial port 1 01-22-2005 10:07 PM
