Old 02-20-2009, 09:40 AM
OutlawMiniLathe is on a distinguished road
Cutting Steel? What Speeds?
Hello All,
I am new to the forum as well new the "Mini Lathes" And lathes in general. I own a 7x12 Harbor Freight Mini Lathe and so far love it! I know how to cut Aluminum but when it comes to steel Im lost.
I do own a bunch of HSS and Cheap chinese made bits From WT Tool. I also have one of those carbide cutters with the interchangable tip...
I was wondering if I could get some help with cutting speeds for diffrent materials. Such as Brass, Cast, Steel, ECT....
Thanks,
Taylor
Owner and Founder of Outlaw Pulling Parts and ACC...
Old 04-11-2009, 10:14 AM
Bump....
Old 04-11-2009, 11:19 AM
Donkey Hotey's Avatar
Donkey Hotey is on a distinguished road
You're going to be far more limited by your machine than by the materials. Since your machine is a given, the two variables that will make the most difference are the materials you choose to machine and the cutters you use. You can't skimp on cutters.
There are also materials that are very difficult to get a good finish on, even with better machines. In particular, some of the common grade mild steels you may come across will cut with a terrible, torn-looking surface finish. Steels with some lead in them are easier to get a good finish.
Brass is another one. I've found that 400 series Naval brass seems to cut & finish much nicer than the more common 300 series (which chips off in chunks and doesn't finish as easily).
Other than that, cut as fast as the machine will generally let you get away with. My teacher told me 25 years ago that if the steel chips weren't coming off between straw-color and pale blue, you weren't cutting fast enough. Aluminum will start sticking to the cutter and smearing on the surface when the cutting is going too fast. A little oil goes a long way. I tend to like WD-40 for general lubricant. It's not too sticky, it smells good and because it's a solvent, the machine wipes down very nicely when I'm done.
And if all of that is too general, do a google search for speeds and feeds. You should find all kinds of ballpark recommendations.
Greg
Old 04-14-2009, 03:32 PM
masonbcaldwell4's Avatar
masonbcaldwell4 is on a distinguished road
generally, for steels I use a cnmg 433, and personally i like the kennametal kc5010 grade. I pretty much use that for most all my turning and facing. for aluminum, for say, a 3 in. dia pc, on a monarch lathe I'll take upwards of .45 off the dia at a time, at .016 feed and at 800 rpm. steels, for a mild steel, cut that to around 2/3 of aluminum. if your carbide is a tpg style, cut both of those to 2/3. brass usually machines similarly to alum, and harder metals, like cres or inconel, start out real slow and slowly speed up, till you see sparks, then back it off!
No, really, just my .002"
Old 04-18-2009, 06:04 PM
Starleper1 is on a distinguished road
One thing you will notice is that you will need to take a much faster cut then you would think to obtain a decent finish on mild steel.
Old 05-16-2009, 10:59 AM
handlewanker is on a distinguished road
Hi Outlaw, as a general rule with mild steel, using HSS (High Speed Steel) tools, 300 rpm for a one inch diam, that is 1" diam steel in the lathe or a 1" diam drill in the tailstock.
Then you just apply a bit of logic and for 1/2" diam double the speed to 600 rpm, Simple.
For 1/4" diam you get 1200 rpm.
Going the other way, for 2" diam you halve it and get 150 rpm, and 4" diam you get 75 rpm.
Use plenty of water/soluble oil based coolant.
The same applies for copper in these diameters.
For alluminium you can double the speed, but use plenty of coolant to stop chips sticking to the tool.
For Brass (cut dry, no coolant) you can go to 1-1/2 times this.
Cast iron is a bit abrasive so you halve the speed for steel and cut dry, no coolant.
Going to carbide you can double the speed on all the above metal diameters with coolant all round.
It pays to get a metal working chart for all drilling and milling ops.
Ian.
Old 05-25-2009, 10:44 AM
vmmfgcorp is on a distinguished road
I am roughing with a .750 diam. cobalt roughing em with a 3.00 length of cut. Machining a full 2.8 loc depth. I plan on taking .050 cuts on the perifery of the metal. Then I plan on using a .750 diam Carbide x 3.00 loc to machine .010 for a finish perifery cut.
What speeds and feeds would you recommend for A2 tool steel.
Cutting Speeds and Feeds ctate2000 General Metalwork Discussion 4 09-22-2008 09:41 PM
Need Help!- Is there any sort of chart that can help me with cutting speeds? ryansuperbee General Metal Working Machines 7 08-01-2008 09:27 AM
What kind of cutting speeds are u running on mild steel? Legion99999 Syil Products 1 06-20-2008 05:34 AM
Cutting Speeds for silver? novacustard General Metalwork Discussion 0 03-23-2007 04:33 PM
Small end mills feed speeds for 1mm steel paulr4 DIY-CNC Router Table Machines 12 08-13-2006 07:29 AM
