Old 02-19-2009, 06:33 PM
hmc710 is on a distinguished road
Surfacing 6061 T651 aluminum
I am surfacing an 8" square 3/4" aluminum plate with a 1" end mill. Half the plate is milled down .200" and the other have is just surfaced .010" I just got a 2" indexable 90 deg square shoulder face mill to try that. Where would I start with feed, speed, and depth of cut? Do end mill calcs apply? Running on a bridgeport series 2 interact 2. Is the face mill too much for the machine?
Thanks.
Old 02-19-2009, 08:57 PM
Jason3's Avatar
Jason3 is on a distinguished road
Talking I was surfacing 6061 with a 2" face mill this morning!
Hi there,
The 2" face mill should be just fine with your machine.
The inserts for my 2" face mill are specifically for aluminum, and have spec for feed and speed on the pack, so I went for the middle of the range and it works lovely.
On my manual 10 x 50 turret mill that means 4200 rpm (.1" DOC), as fast as the power feed will go for roughing then a slower finish pass at .01" - 02" DOC. Stepover was about 90%. Leaves a very nice finish, kind of like a rainbow reflection at the right angle
Best regards,
Jason
Old 02-20-2009, 07:10 AM
Face mill
Thanks Jason, you running that with coolant or without?
Old 02-20-2009, 02:34 PM
Jason3's Avatar
I use a bit of CRC, which as far as I can tell is the local equivalent of WD40 - just a squirt before each pass helps the finish, and stops the chips sticking to the cutter.
Flood would probably be better, but I have yet to set up a decent shield to contain the mess
6061 aluminum finish ?? twocik Mass finishing equipment/media/stratigies 21 11-01-2008 11:37 AM
Need Help!- Mill Bit 6061 aluminum Ed Williams General Metal Working Machines 3 03-16-2008 10:45 PM
Which tool bit type for surfacing aluminum with a fly cutter? cnczoner General Metalwork Discussion 5 01-03-2008 01:54 PM
machining 6061 aluminum conlimon Benchtop Machines 16 09-19-2007 07:20 PM
Surfacing Aluminum rcazwillis General Metalwork Discussion 11 04-08-2005 10:29 PM
