Old 02-19-2009, 06:33 AM
Robin Hewitt is on a distinguished road
Belleville washers on ball screws
I'm just remaking my bench sized mill a bit, want to get it right this time.
I have a notion that the best way to hold a ball screw is under tension between two axial bearings. The most compact way to get that tension is with Belleville washers.
From somehere in my dim and distant past I also have a notion that 560 lbs of tension is about right, a quarter ton. Does that sound credible or am I way off the mark?
To gauge the tension I'm thinking 2 washers with different rates facing each other. One crushes flat at around 560lbf and acts as the gauge, the other is altogether stiffer and still has some way to go.
Bellevilles don't exactly appreciate being crushed flat so guess I'd have to replace the lighter one whenever I wanted to recalibrate.
Old 02-19-2009, 08:16 AM
LeeWay's Avatar
LeeWay is on a distinguished road
I personally don't think bellvilles are needed in a drive bearing setup. Thrust washers are more important. You can use a pair of those, one on each side of a standard good quality bearing and apply preload with the nut. You can locktite the nut or back it up with a locknut to hold the assembly.
I did something similar on my lathe and got great results. Bellvilles just aren't needed for this.
Lee
Old 02-19-2009, 10:34 AM
What is a Belleville if not a thrust washer?
I started without any intentional spring in the system then added a die spring PDQ.
Now I'm remaking it (with the benefits of CNC and hindsight) I want to make it pretty and do all the things I didn't realise I needed last time around. Things like double ball nuts, more iron, less aluminium etc. Also I won't restrict the X,Y movement when I can so easily extend it. I have even remembered a conduit attachment point on the X.
Bellevilles it must be, only thing is choosing the right Bellevilles
Old 02-19-2009, 10:45 AM
Robin, Have you also considered wavesprings? www.smalley.com
Just something else to add to the confusion. lol
Dick Z
DZASTR
Old 02-19-2009, 11:36 AM
and I'm quite easy to confuse I'll give you that
Isn't the wavespring designed to put a long spring in to a short space? I rather liked the enormous rate to be had from a Belleville for this application.
The price is good to.
Fixed Bearing w/ Belleville washers CNCDevil Linear and Rotary Motion 19 04-16-2012 08:44 AM
ball screws matt DIY-CNC Router Table Machines 7 05-21-2007 01:36 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
Ball screws BluesMagoos General Metal Working Machines 1 01-08-2005 12:09 PM
ball screws anyone! turmite DIY-CNC Router Table Machines 0 01-13-2004 07:25 PM
