Old 12-17-2004, 05:18 AM
UKRobotics is on a distinguished road
Axis Movement
Somthing i've noticed while researching different CNC milling/routing machines is that there are so many combinations of possible axis movement.
The 'traditional' configuration seems to be where the table moves in x and y and the cutter moves in the z axis, but I have also seen machines where the table only moves on the y axis and the spindle motor moves X and Z. In addition to this i've even seen machines where the spindle motor moves X,Y and Z and the metal being machined doesnt move at all.
What i'm trying to establish here is what is the best method to use ? As i'm building a CNC mill from scratch I have the choice to use any of theese options so its just a case of what is best.
What are peoples opinions on this ?
Dom
http://www.ukrobotics.com/projects
Old 12-17-2004, 08:53 AM
Al_The_Man's Avatar
Often with a Milling machines etc, it is a case of deciding which is the largest mass to move and how practical it is to move the tool in all three axis, many of the large mills that use this method have either a detached work table or the work area consists of a palletising system that moves the work in and out of the work area.
Al
Old 12-17-2004, 01:33 PM
Torsten's Avatar
Torsten is on a distinguished road
Every conceivable methode of axis arrangement has been used successfully.
Each comes with it own drawbacks and advantages, if there where a best
then everybody would be using it.
It all depends how you are going to use it.
Partsize envelop, Partweight, Toolweight variation need to also support spindlemotor?
Feedrate desired, acceleration requirements, Setup flexibility.
Material to be machined, torque range, chip disposal methode.
All must be considered then you will be able to
define the best compromise for a machine structure.
Well I allmost forgot Budget, its not cheap to build the best so another constraint here.
Good Luck
CNC Glossary CNCadmin CNCzone Club House 17 03-09-2008 03:08 PM
4020 4th axis problems little bubba Fadal 3 06-13-2005 09:08 PM
2 axis to 3 axis conversion drembedded Bridgeport and Hardinge Mills 10 10-27-2004 11:32 AM
4th axis movement (and a few other gen ?s) corpse General Metal Working Machines 2 08-04-2004 06:13 PM
My Lathe project; might CNC it one day Stevie General Metal Working Machines 86 06-21-2004 08:27 PM
