Old 02-18-2009, 12:10 AM
integerspin is on a distinguished road
matsuura oil line valves?
I wondered if any one knew what the valves were, I assumed they were one way valves. I don't get appreciable flow thru the ones I have checked.
The machine hasn't had any axis in motion for a considerable time now so after I cleaned the oil lines, they had been disconnected while the pump was off, I pumped oil with a squirty can connected to each axis main oil line till oil flowed out from the surfaces.
I was amazed how well the axis moves when I stick a cordless drill battery on the axis;-) x and y are nice'n'oily.
The z axis no oil came out so I pulled a few of the easy to get at lines and there appears to be oil flow. I pulled a valve off the main manifold, every line coming off the manifold has a one way[?] valve, no oil flows out of the valve, oil comes out of the manifold, so the valves are obviously not flowing enough/blocked.
I don't want to destroy one so was a bit carefull, I blew thru it with 100psi and the bit of brake cleaner in the thing blew thrugh but not a lot of flow. The are similar valves on the oil lines on my lathe, they come apart really easy, doesn't look like these come apart so easy.
Problem- Inexpensive Solenoid Valves greenchair RC Robotics & Autonomous Robots 1 09-23-2008 09:59 AM
Where to find push-button oil hole valves? Claven2 Mini Lathe 6 04-17-2008 10:01 AM
Brass needle valves mrwhittle General Material Machining Solutions 15 11-07-2006 07:07 AM
valves for oxy/gas torch? redneck79 CNC Plasma and Waterjet Machines 1 10-11-2006 11:26 PM
Ball Valves SIMONSIGNS Mechanical Calculations/Engineering Design 7 04-27-2006 11:16 PM
