Old 02-17-2009, 12:42 PM
federicod is on a distinguished road
Lathe or Mill Casting
I'm trying to develop a basic CNC lathe or mill. Any body know where I can buy lathe or mill castings? The best option would be a complete casting, I just want to put the linear guides, ball screws, electronic, CNC, etc, over this casting.
I need only one at first moment but I don’t know in the future.
Thanks for your help.
Old 02-20-2009, 11:10 AM
cnc2 is on a distinguished road
Make molds using lost foam technique & go to a foundry to have them filled with iron.
It will be the nearest thing to your size/weight needs. they will require a bit of finishing & drilling the surface were you'll put your rails...at the end it might be cheaper or better than a ready made casting...if you want a full size lathe or mill don't go that way but if you want a hobby sized machine the size of an X3 or so, you should go that way.
Here's a vid of a diy cnc lathe on yotube, the frame was welded but you can make a cast version of it.
Anyone correct me if i'm wrong.
Thanks !
cnc2.
Should I get a mill or a lathe? (Turning with a mill?) JMcDonald General Metal Working Machines 6 11-02-2008 11:02 PM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 02:06 AM
Should I do a mill or lathe sgman Mini Lathe 14 08-05-2008 05:59 PM
mill or lathe? mog5858 CNCzone Club House 7 05-28-2008 08:21 AM
Am I a mill or a lathe. Art Ransom Mach Mill 1 10-03-2006 09:08 AM
