  #25   Ban this user!
Old 02-23-2009, 02:31 PM
Kiwi is on a distinguished road
Originally Posted by Un4givn View Post
...(BTW are you using solidworks? If you are I can send you the solids I created with all the sketches still in place.)
Yes...SW2007
  #26   Ban this user!
Old 02-23-2009, 04:35 PM
cnc2 is on a distinguished road
Originally Posted by Kiwi View Post
The VB loop output is the angle and the X dimension so only the 'A' and 'X' need to be added to become GCode.
As the output is made up of 'A' rotations and 'G01 X' movements there is very little GCode knowledge required....
For this exercise you need to understand where the tool should be as the disc rotates so a basics of trig is required. I do a drawing with CAD to confirm the figures.
So this one falls out in the category of simple yet magnificent programs
Many thanks Kiwi for this great explanation.
cnc2.
  #27   Ban this user!
Old 02-23-2009, 06:18 PM
Originally Posted by cnc2 View Post
So this one falls out in the category of simple yet magnificent programs ...
Here is the loop that does the calculations. I have added the values for the end point in place of the variables for help to follow.
Private Sub Command1_Click()
MaxAngle = 2.1553
For Angle = 0 To MaxAngle Step 1
X = (460 + (10/2)) / Cos(Angle / 180 * 3.14159)
GCode = GCode & "A" & Angle & " X" & X & Chr(13) & Chr(10)
Next Angle
txtCode.text = GCode
End Sub
  #28   Ban this user!
Old 02-23-2009, 11:08 PM
Thumbs up
MaxAngle = 2.1553
Next Angle
End Sub
Oh that's tight man ! Thanks a lot !
You also made it open source
The code is much simpler than it looked like when it was hiding behind that interface
I could implement it in C or pascal but it wouldn't look so good because i'm still programming in DOS (& run it in the command prompt)& i've a basic knowledge of OOP & i'm thinking about VB now.
Thanks for sharing !
cnc2.
C - Axis Face Contour w/ Mastercam rexster_001 Mastercam 9 12-02-2011 05:36 AM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
Need Help!- c-axis cross contour help fenix728 Mastercam 2 12-08-2008 08:31 AM
Problem- Beaver VC 15 Vertical Machining Center MACHINEYARD General Metal Working Machines 0 11-11-2008 01:40 AM
Need Help!- CNC Vertical machining center soumen Mori lathes 0 03-11-2008 09:06 AM
