  #13   Ban this user!
Old 02-16-2009, 07:18 PM
lclore is on a distinguished road
one other thing... the existing speed controller can be tested by disconnecting the motor and connecting a voltmeter to the output (A+ and A-). This is best done with an analog meter if available. You should see very steady output voltage (no needle movement if an analog meter). If its stable but the motor torq just isn't there (load increased with motor) then it is having trouble delivering the current under and is junk.
You can measure the voltage with the motor connected too. If the first test above is ok, and you get to this point and the measurement is all over the place, then the motor has issues.
Disconnect the motor, measure the resistance and compare against the specs is a good idea too. Good Luck!!
  #14   Ban this user!
Old 02-16-2009, 11:06 PM
KEN BANGERTER is on a distinguished road
DC MOTOR QUESTION.
I STARTED MY INITIAL POST, "IF ALL ELSE FAILS". PLUGGING A DC MOTOR FOR INSTANT REVERSAL REQUIRES A DC RATED SWITCH, A CAPACITOR TO ABSORB THE ARC IS A GOOD REFINEMENT. I HAD USED PLUGGING ON A 3/4 HP PARALLEL WOUND FIELD DC MOTOR, FED WITH 1/2 WAVE RECTIFIED DC AT 90 V WITHOUT ANY TROUBLE USING A SQUARE D REVERSING SWITCH ON A 9 INCH SOUTH BEND LATHE FOR TAPPING, SINCE 1970. NOT IN PRODUCTION BUT USED FREQUENTLY AND STILL GOING STRONG. I RECENTLY REPLACED IT WITH AN INSTANT REVERSING 120 V AC LATHE MOTOR, STILL USING THE ORIGINAL DRUM SWITCH, SO I COULD USE THE DC MOTOR ON AN OTHER APPLICATION.
Motor Question buddym DIY-CNC Router Table Machines 1 02-11-2009 06:35 PM
Stepper Motor Question m.wanat Stepper Motors and Drives 0 09-01-2008 10:06 PM
Motor Question DistortedDesign Joes CNC Model 2006 11 03-07-2008 09:01 AM
Spindle motor question Kieron DIY-CNC Router Table Machines 2 09-21-2007 06:43 PM
Stepper Motor Question bcromwell General Electronics Discussion 3 08-31-2004 02:42 PM
