Old 02-15-2009, 01:37 AM
rholliday is on a distinguished road
Question Belt drive or direct drive?
I am converting a Sharp manual mill to CNC 48" x travel and 16" y
What is the advantage of a belt drive over a direct drive?
If you use a belt drive what is the best pulley ratio?
I have a 1160 in/oz Keling KL34H2120-42-8A Stepper and G201 Geco Drive
and will be using Mach3
Old 02-15-2009, 10:36 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi rholliday. Welcome to the Zone!
First, I assume that you are talking about connecting stepper to lead screw either directly or with timing pulleys and belt--NOT about Belt drive system of driving router axes--Which is a whole 'nother thing.
SERVO motors have good torque into high rpms and need to be geared down to produce real work. Servo motors are usually geared with timing belts and pulleys.
STEPPER motors have max torque at rest and lose it as they increase in speed. Gearing with pulleys is often a wash, because motor must run faster thereby losing torque to screw.
That's a large stepper motor and large motors tend to run slower than smaller motors anyway.
I recommend direct drive, or if pulleys ARE used, then 1 to 1 ratio.
Wire the motor Bipolar Parallel and power it with 72-80V PSU for best results.
CR.
Old 02-16-2009, 06:21 PM
CR thanks for the reply.
I just ordered the RULAND couplings for the X drive.
I will do the X drive first then the y and later the Z
Still looking for ball screws. the backlash on the X is .020 and .014.
Direct Belt Drive? Regnar DIY-CNC Router Table Machines 20 01-10-2009 06:35 AM
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 10 03-01-2008 05:02 AM
Direct belt drive like Carlson Plotter? Knut CNC Plasma and Waterjet Machines 1 09-15-2007 10:44 PM
Direct Belt Drive Router keyne CNC Wood Router Project Log 13 08-09-2007 02:57 AM
X3 conversion using big servos - direct or belt drive?? messar Benchtop Machines 13 01-27-2006 04:19 AM
