Old 02-13-2009, 10:39 PM
klaymonster is on a distinguished road
Question Z axis.. Why so limited??
Can someone explain to me why the Z axis is so limited in a lot of these CNC machines??
I am new at the hobby and am still shopping for my first machine but i cant seem to find a machine with the Z depth that i would need for my desired field. (large part injection moulds for automotives accessories or even bodykits)
I was very near settling for the Romaxx HS-1 (~12"x18"x3") Great price ($2400) decent enough work area, but that 3" Z axis just kills me! It seems so awfully limiting. Being that i am making moulds i figured i could creatively notch and stack plates bringin them to the depth i needed, but its so frustrating not just to have just been given a reasonable Z travel by the manufacturer! Am i looking in the wrong type of machine?
Ideally i would have a machine capable of 3'x6'x1.5' poweful and reliable enough to machine aluminum regularly (hell i'll even add steel since i am speaking IDEALLY) I only have three grand to invest so I am aware that i am S.O.L on that one... (unless you all know of blueprints i could get and build it myself) But I just wonder if you can all tell me
1.why generally these machines have so little Z travel
2.with proper stuctural support and proper software, could one build something with maybe a couple.. even a few feet of Z travel?
3.could it machine aluminum and be built at the 3 thousand budget?
4.what about something more modest?... 2'x3'x1'
I've said a mouthfull and i appreciate anyone thats read it all you guys are great!
Old 02-14-2009, 12:20 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Routers are typically used to cut flat sheets of material. They don't need a lot of Z for that. Routers are not as rigid or accurate as a metal milling machine and so can have large X-Y envelopes.
Milling machines with the work envelope that you desire would cost many thousands of dollars and weigh many thousands of pounds.
If you can live with a 12 x 5.5 x 8 inch envelope, and up to 10,000 RPM spindle, then the $1700 DG1 Taig/Gecko CNC mill is a Best Buy!
http://deepgroove1.com/cncmill.htm
More specs:
http://www.taigtools.com/mmill.html
CR.
Old 02-14-2009, 07:33 AM
ger21's Avatar
The reason is that it's far more difficult than you think to build a rigid enough Z axis. The Z axis acts as a lever, so the longer it is, the easier it is to bend or flex. You're underestimating the forces involved, especially if you want to cut steel.
Old 02-14-2009, 09:57 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Way over $100,000 and weigh over 60,000#.
For a Mill of course - a router has no business attempting to cut metal
www.integratedmechanical.ca
Old 02-14-2009, 12:26 PM
Khalid's Avatar
Khalid is on a distinguished road
Adding to others, you will need long tool if you make a pocket in 1' log upto 10" deep... and the long cutter will have its own issues
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Old 02-14-2009, 07:24 PM
keebler303 is on a distinguished road
That Romaxx has belt drive axes too, or at least the Y axis does. I wouldn't think it would even work very well on aluminum. Steel is out of the question.
Matt
Old 02-14-2009, 07:28 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
I think your looking for a gantry mill or a bridge mill, probably out of your price range though.
Old 02-14-2009, 08:32 PM
This little mill should fit your work envelope a little better--Although I'm sure it's way over budget.
MIKINI MECHATRONICS - NEW CNC MACHINING CENTERS 16"x10"x16" 2000 lbs Linear Rail
CR.
Old 02-15-2009, 03:20 AM
Thumbs up
I really like the taig machine! Aside from the fact that the work envelope is slightly smaller than i had hoped, i feel like its a great deal and a great machine. I only wonder now is there anything else i need or will this be a turnkey system at 1700 dollars? The computer i have already, but what else will be required? Is there a good starter kit for bits and endmills? thanks again you guys are a huge help!
Old 02-15-2009, 09:50 AM
The tough little Taig mill comes WITH a vise and some drills/end mills. It is turn key with some assembly required. Bolt together and square up mill, bolt on motors, (all are the same) connect cables and PSU box. Connect computer cable and install Mach3. Start making chips.
You will need a 6 foot straight-thru male/male DB-25 serial cable to connect it to your computer, and a big red Estop switch:
http://kelinginc.net/CNCPackage.html
You will also need at least Mach3 (DG1 has it at a discount) and maybe a cam program like D2nc:
http://www.d2nc.com/
You can add more tooling as needed.
Just make sure you get the Gecko mill--The other one may have unreliable electronics. There are mill options from DG1 like home/limit switches. You will need at least home switches.
Depending on what you make, you may also need CNC 4th rotary axis. You can always add that later--G540 control box is already wired for it.
Here is a list of Taig acessories--some of which are for a lathe:
http://www.taigtools.com/accessories.html
This place has some Taig stuff too:
http://littlemachineshop.com/product...?critFast=taig
If for any reason, this does NOT work out for you, it IS a highly popular item and you can recoup much of your investment by selling it on ebay.
CR.
  #11   Ban this user!
Old 02-15-2009, 12:42 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Lemme get this straight. We went from a work envelope measured in FEET to a tiny little Taig?
Does not computer for remotely the same projects.
If you're looking for a smaller machine, I'd do an X2 similar to Hoss's machine.
Just be aware, these machines are wildly different than what you were originally asking for.
Cheers,
BW
  #12   Ban this user!
Old 02-15-2009, 12:50 PM
The Taig is a very capable turnkey small starter machine that can do real work and be resold easily when he outgrows it.
The Grizzly X3 with its potential modified 18 x 8 x 18 envelope would be a better choice for larger machine, But would have to be torn down and converted to CNC from manual. Cost about $3500. The Taig could make all of the CNC mounts to convert the X3 for a savings of about $500.
http://grizzly.com/products/Mill-Drill/G0463
CR.
Learning CNC with limited resources balalhaider General CAM Discussion 1 04-01-2011 07:14 AM
Denford Limited UK Bradders Product Announcements & Manufacturer News 0 04-10-2008 07:14 AM
DIY Dust Extractor on a limited Budget. Imagineering WoodWorking 4 12-05-2005 08:28 PM
Limited Search depth. ynneb Forum Questions or Problems 0 11-15-2004 04:51 PM
Gecko's limited to only 20A ? samualt Gecko Drives 26 09-23-2003 08:24 PM
