Old 02-13-2009, 04:02 PM
samsagaz is on a distinguished road
Low Budget Machine for Metal Working?
Hi guys, im planning to purchase an small machine for work in metal, table need to be small, biggest pieces will be 20x20cm.
Want to know if exist some kit that can fit my requeriments.
Mainly will be used to cut some shapes from mtal, and maybe draw some fonts in the metal.
Thanks in advance.
Old 02-13-2009, 10:44 PM
klaymonster is on a distinguished road
this topic has been covered a lot on these forums. dont quote me but i beleive sherline and taig were the names that come up most often for small work area and high accuracy. do a search.
Old 02-14-2009, 11:54 AM
acondit's Avatar
acondit is on a distinguished road
Thanks in advance.
A number of milling machines will probably handle 20cm in the X direction, the problem is you have to look at a much larger mill to find something that will handle 20cm in the Y axis. My RF30 (around column mill weighing 500-600 pounds) will only handle about 7.5" (19.05cm) but it will handle 20" (50.8cm) in the X axis.
A number of routers will handle those sizes but they typically aren't designed for precision metal working.
Alan
http://www.alansmachineworks.com
Old 02-14-2009, 12:18 PM
Thanks for your support!, Y axis are not the problem! 20x10 will works OK.
i think that minimun 5cm Y will be OK too, but i need at least 20cm X (or more).
My first low budget machine- tutorial Honus DIY-CNC Router Table Machines 9 01-11-2009 10:22 AM
Metal working project Stifler51 General Metalwork Discussion 11 01-08-2009 08:45 AM
Job Opening Product Manager - Metal Working pspiech Employment Opportunity 0 04-09-2008 06:48 AM
Method of production qeustion(metal working project) NOODL3 Mechanical Calculations/Engineering Design 2 03-31-2007 11:52 AM
MY Metal Working Page WOODKNACK Steam Engines 4 06-03-2003 09:37 AM
