Old 02-05-2009, 09:39 PM
bishb25 is an unknown quantity at this point
ProtoTrak MX3 DNC rs232 cable pinouts
Hi all,
Would any of my fellow prototrak users know the correct pinout for sending programs from a DB9 (9pin) serial port to the DB25 port in the Prototrak MX3?
I got a diagram from SWI which shows 3 different sets of pinouts
1. 25 to 25pin cable (the cable that came with the DNC upgrade)
2. 9 to 25 pin adapter
3. 9 to 9pin cable
It would appear since I have the 25 to 25 pin cable that came with the DNC kit from SWI that I would only need to make the adapter from diagram 2. However, I have hacked an old 9 to 25 cable I picked up at a used computer store to match the diagram and still I cannot successfully send a DNC program to the control.
If anyone has a working 9pin to 25pin setup would you mind spending a little time with an ohm meter and help me get the right cable.
I would also be open to setting up the prototrak to accept USB if anyone has a solution.
Old 02-06-2009, 09:05 PM
Let me ask it this way:
Is anyone using a Db9 to DB25 cable for DNC to a Prototrak MX3 successfully?
Old 02-14-2009, 12:04 AM
Well, If anyone is interested I got RS232 working on my ProtoTrak MX3.
I never did get the right pin out for a 9pin to 25 pin cable (obviously, cause' I'm the only one replying to my posts). What I got was a BAFO BF-800 USB to serial DB25 adapter. The adapter plus the 50ft DB25 to DB25 cable that came with the DNC kit from SWI works very well. Till now I could only find USB to DB9 adapters, and was led to believe by many CNC guys that DB25 adapters did not exist.
Thanks to all those who viewed my thread. I know you would've helped if you could.
Old 06-28-2009, 09:13 PM
The BAFO works great in windows XP, but I could not get it to work reliably in Win98SE or at all in Linux. Southwestern industries recommends using Hyper-terminal, and I agree, I got my best results using it vs bobcad, predator, or any other DNC software. The best part is hyper-terminal is free with Windows 95 though XP. Vista doesn't have it but you can buy an enhanced version from it's creator. Just Google "hyperterminal."
For best results I suggest using a PC with a dedicated serial port, Hyper-terminal, and the appropriate cables. The RS232 settings are on the back of the control pendant. If you don't have a serial port use a high quality usb to serial adapter like the BAFO. The cheapo's don't work. I don't have any problem sending and receiving .CAM, .MX3, or .MX2, but I still have issues with long DNC programs. I think it's the old worn-out control on my particular machine.
Need Help!- RS232 cable Zep Machine Problems, Solutions , Wireless DNC, serial port 1 09-05-2008 09:46 AM
rs232 cable Dar Bridgeport and Hardinge Mills 7 12-13-2007 01:51 AM
Fanuc om-d rs232 cable Julian M Fanuc 4 09-09-2006 07:41 AM
Fanuc om-d rs232 cable Julian M General CNC (Mill and Lathe) Control Software (NC) 2 09-01-2006 06:20 PM
V2XT RS232 pinouts needed zcases Bridgeport and Hardinge Mills 3 04-15-2005 08:15 PM
