Old 01-31-2009, 02:45 PM
cbrussell is on a distinguished road
Question How to Add Digital Depth Guage To Drill Press
Although I have been lurking around here for a couple of years, this is my first post. I hope it is under the correct sub forum.
I have a floor mounted Cratfsman Drill Press to which I would like to add a digital depth scale. I purchased a Grizzley scale but am a bit puzzled as how to "elegantly" mount it. I figured it there was anyplace which could steer me in the right direction it was here.
Craig
Old 01-31-2009, 03:01 PM
Al_The_Man's Avatar
A drill press is a hard item to add a scale to, you have to get to an exposed part of the quill to mount the reading head to.
Its a bit late now if you already have it, but I would have looked at putting a rotary encoder on the operator shaft that usually goes through the head and quill rack gear.
There are scalable readouts that can be hooked up for a readout, such as Red Lion etc.
Also many of these type DRO's are 2 axis minimum, if you only need one?
Removal of the drill press depth stop threaded rod devinchi Shopmaster/Shoptask 4 03-14-2010 10:10 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 02:32 PM
Center Drill Drill Depth bowersjack General Metalwork Discussion 4 01-28-2008 09:53 PM
Problem with drill depth Alan S Post Processors for MC 2 11-03-2005 03:23 AM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 06:03 PM
