  #37   Ban this user!
Old 02-03-2009, 03:38 PM
Plexiglas is not suitable, it will crack and could break calamitously leading to fragments of everything everywhere.
The stop pin is purely a stop pin to set the length. If you left it in while cutting it would probably be okay...but if you daydream along like I do sometimes and retracted the blade while it was running the cut-off piece could jam between the blade and stop pin.
The fit does not need to be really snug, 1/32" clearance would be fine because you are pulling the stock to twist it in the tube and take up a small amount of clearance.
Just use 1/4" bolts for holding it down.
  #38   Ban this user!
Old 02-03-2009, 07:10 PM
martinw is on a distinguished road
Dear toolmetal and Geof
That link to jigs for a mitre saw had me gasping in admiration..
http://www.woodnet.net/plansnow/mitersawtips.pdf
It all seems so obvious now. It didn't 24 hours ago.
Thank-you
Best wishes,
Martin
What is the best way to cut thin wall brass tubing? lerman General Metalwork Discussion 9 03-27-2009 02:58 PM
Problem- milling thin wall brass tubing jackie_burton@m General Material Machining Solutions 11 09-29-2008 03:46 PM
Taking thin slices on a bandsaw... digits General Metal Working Machines 4 04-19-2007 10:08 AM
Steel rectangular/square tubing wall thickness pstockley General Metalwork Discussion 0 01-27-2006 01:56 PM
Steel square tubing for frame samualt DIY-CNC Router Table Machines 10 08-20-2005 08:44 AM
