Old 01-25-2009, 09:02 AM
jdgromi is on a distinguished road
Question Chuck & Jaws
My lathe chuck ( jaws ) have a eccentricity of 0,004". I would like to correct this problem. What is the better way to correct and how can I do that? I would like to grind the jaws.
Best regards
Jean-Denis
Old 01-25-2009, 09:31 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hello Jean. Welcome to the Zone!
Maybe this will be helpful:
http://www.varmintal.com/alath.htm#Toolpost_Grinder
http://www.varmintal.com/alath.htm#Truing
CR.
Old 01-25-2009, 05:28 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
or a boring bar works for me. It's a common problem with a scroll chuck. The scroll on cheap chucks isn't very precision, machine the jaws for one diameter and they will run perfectly true, open up to a larger diameter and they will probaby run out again.
5c collets are much more precision and give a much better grip on the material, yet have a smaller thru bore(in most cases) and require changing between hex stock, round stock and diffrent diameters.
Welcome to the wonderful world of precision machining!
Old 01-29-2009, 06:48 PM
KD05 is on a distinguished road
We use softjaws on our scroll chucks. Indicate the chuck in round, chuck on something to put tension on the masters, and start tooling out the jaws. We run lots of molds, and if the jaws are tooled right they will run true everytime. We often tool out several diff. diameters on one set of jaws so you dont have to change jaws all the time. A good scroll chuck always helps.
Newbie. Need to make soft chuck jaws for Mori lathe bob1112 General Metal Working Machines 10 03-13-2008 09:07 PM
milling chuck jaws theatrewizard Haas Mills 4 02-28-2008 11:09 AM
CNC Lathe chuck with adjustable Jaws ? Larken General Metal Working Machines 4 02-03-2008 11:47 AM
Boring soft chuck jaws for ID holding? SRT Mike General Metalwork Discussion 9 10-31-2007 11:52 AM
truing lathe chuck jaws wrenchcruncher General Metal Working Machines 2 01-17-2007 01:03 PM
