Old 12-03-2004, 05:25 PM
studysession is on a distinguished road
Help identifying this please
The attached picture is someone cutting a gear on the mill.
What is the tool called that is being used to hold the gear? And where can I get one?
Thanks for the help!
Please check out my CNC blog
http://cncinside.com
Old 12-03-2004, 05:28 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
That would be an Indexing head...you can get them from most any tooling supply house. MSC, Enco, and many more.
Old 12-03-2004, 05:56 PM
Thanks - do any of those places have a website so I can see how much they are? I am new to this and want to get one just like in the picture.
Thanks again.
Old 12-03-2004, 06:12 PM
I did some searches on Google and I can find information on indexing heads but not places that sell them.
Any idea of costs??? I am hoping that it is affordable.
Thanks again!
Old 12-03-2004, 06:25 PM
Al_The_Man's Avatar
I think the name is also dividing head here is a link to make your own http://www.atmsite.org/contrib/JSAPP...e/divhead.html
Al
Old 12-03-2004, 06:26 PM
wms's Avatar
wms wms is offline
Moderator
Also called a Dividing Head. Try a google with "Dividing heads"
http://www.use-enco.com/CGI/INSRIT?PMAKA=203-
4000&PMPXNO=953522&PARTPG=INLMK3
Although the one at this link may be bigger than you need.
Old 12-03-2004, 06:27 PM
wms's Avatar
wms wms is offline
Moderator
Sorry Al got there before me..should have told you about Dividing head in first post. Me bad.
Old 12-04-2004, 02:39 AM
Thanks - I do not think I am at the point where I can make one yet. I just want to buy the finished product of whatis in the picture I posted.
Any help is appreciated.
Old 12-04-2004, 08:19 AM
mtechserv is on a distinguished road
These are typically referred to as an indexing head or dividing head. There are many machining supply companies in the US that sell these. Most of the new models are manufactured in the far east. I've never used any of the far east manufactured units, so I'm not sure of the quality.
Here is a link to MSC, a large industrial supply company in the US.
http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=1656786
That web page shows a typical dividing head. Prices may vary depending on what size you decide to buy.
You could also search ebay for new or used dividing heads. There is usually several on there at any given time.
Old 12-04-2004, 08:23 AM
Thanks for the replies!
Looks like there are different kinds:
http://www1.mscdirect.com/CGI/NNSRIT...PMPXNO=1795236
How do I tell which one I need? Have any links to the ones made in the far east? I searched EBay and from what I can see. There are not to many to choose from.
  #11   Ban this user!
Old 12-04-2004, 10:00 AM
OK - did another search on EBay and instead of indexing head I put in dividing head and had better luck. Seems like there are many different kinds. How do I tell which is the correct one I need?
I want to make 48 pitch and Mod-1 pitch gears. Thanks!
Old 12-04-2004, 10:47 AM
Gold Member
Ken_Shea is on a distinguished road
Studysession, the unit you link to at MSC is the import version, a nice size and that it can be rotated up or down could be useful. These are available from Enco for $245 and is the unit Ward linked to I think. Since MSC and Enco are both owned by the same company, likely it is the same unit. Most of us hobby machinist will have to purchase the import versions as the cost difference is just too great. The high quality version are also very heavy, many over a 100 pounds (this is good). The height would control the maximum diameter gear you could machine, and I would suspect that it will index any number of teeth you or I could ever imagine needing.
The geometry of the gear you are needing to cut is controlled by the gear cutter and not the dividing head, the dividing head provides for precise indexing between each gear tooth.
Help needed identifying Tool holder and Collets gtslabs General Metal Working Machines 0 03-20-2005 01:25 PM
Help identifying stepper motor torque. MrBean Stepper Motors and Drives 0 02-06-2005 05:29 PM
