Old 01-19-2009, 06:43 PM
PhoenixMetal is on a distinguished road
NT35 Taper - Same as BT35?
I just purchased a used Kitamura Vertical Machining Center, and I'm not sure what taper tool holder it takes.
The manual says it takes No.35 Taper, which doesn't quite help me to determine wither it is CAT, BT or something else. The model numbers for the Kitamura-brand toolholders listed in the manual all start with NT35. So is there a taper style called NT35? If so, is this the same thing as BT35?
I do know that other Kitamura machines use BT35, but I suppose it is possible that they offered different options so I want to be sure.
If any of you have any information, I would greatly appreciate it.
Old 01-20-2009, 09:28 AM
Kevin Taylor is on a distinguished road
NT35
Seem's like Nt cat Bt all have the same basic taper the hitch is in the drive lug's and the Tool changer flang if the machine has a tool changer also the retinton knob for the drawbar asuming it has one Good luck Kevin
Old 02-21-2009, 12:10 AM
cweiss is on a distinguished road
BT35 is what you are looking for. You could contact Kitamura, but we fix them everyday. We have never seen another 35 taper other than BT35.
Old 02-21-2009, 09:09 AM
Yup, you're right - Kitamura confirmed it is BT35. Boy, there weren't many options when buying toolholders for that size... It was Lyndex or Lyndex! Not that that's a bad thing - its a quality brand.
Old 02-23-2009, 02:21 PM
integerspin is on a distinguished road
I have a BT35 spindle, all my tooling is Nikken, but my machine has a manafacturers sticker on the head that says use only Matsuura 35 taper tooling!
There are loads of different pullstuds, the manual for my machine has a drawing of the stud. I found a site listing pullstuds and the dimensions, I couldn't believe there wasn't some sort of standard. Kitamurea and Matsuura use different pullstuds. If you buy tooling and end up with any of the pullstuds to suite my machine let me know, they are easy to identify they have a .539 diameter knob.
What's the taper on this? la_coterie Commercial CNC Wood Routers 4 02-20-2010 03:15 PM
Cat 40 Taper wickedcool General Metalwork Discussion 1 06-26-2008 03:01 PM
Taper 40 N.S. professor Industrial Hobbies (Support forum) 2 01-13-2007 08:14 PM
BT to CAT Taper machinistJ Fadal 2 02-14-2006 03:36 PM
R8 taper lt paul General Metal Working Machines 2 06-10-2004 11:31 AM
