Old 01-19-2009, 07:02 AM
vroemm is on a distinguished road
OPTIMUM BF20L mill, z-travel exactly from table height ?
Hi..
The OPTIMUM BF20L has a z-travel of 280 mm.
http://www.optimum-machines.com/prod...rio/index.html
How is this exactly calculated ?
If the drill-cutter head is down, does it touch the table ?
Suppose a cutter sticks 100 mm out of the cutter holder.
Does the distance between the cutter and the table then become 280 - 100 = 180 mm ?
Or will it be a little bit more then 180 mm ?
How much more ?
Thanks..
Vroemm.
Old 01-19-2009, 04:01 PM
chalky is on a distinguished road
On my Weiss machine, pretty much the same as the Optimum, the spindle taper nose is 30mm above the table when fully wound down and 330mm above when fully wound up.
Optimum BF20L CNC conversion JanHenning Vertical Mill, Lathe Project Log 19 03-11-2009 12:09 PM
X2 with stiff table travel? isaac338 Benchtop Machines 1 09-25-2008 10:21 AM
OPTIMUM BF 20 Vario Mill Made in Germany gcamlibel General Metal Working Machines 33 02-03-2008 09:01 AM
What's the max table and head travel on your X3 mill? JMcDonald Benchtop Machines 4 12-21-2007 01:36 AM
Ideal table height for a mill ranchak General Metal Working Machines 2 11-20-2007 02:19 PM
