Old 01-17-2009, 03:45 PM
KyleH2's Avatar
KyleH2 is on a distinguished road
Coolant through on a manual tailstock?
Background: I have some Cleveland coolant through HSS drill bits and am holding them in a MT3 ER32 Collet chuck which has a coolant hole at the back. I am using this to drill a 21/32 hole in 1020 Steel and 304 SS on my 13x40 gear head MSC lathe and would really really like to use either air or coolant if possible. I have a coolant setup on the lathe but of course spraying it into the hole just makes a huge mess. If I could use the coolant holes already in my drills I think it'd really help me up productivity.
My question: Can I some how get air or coolant into the tail stock so I can extend tool life?
Thanks in advance. I am 20 years old and just starting out. I am also trying to get a Hurco KMB-1 3-axis CNC up and running both of my machines are in my garage.
Old 01-17-2009, 03:58 PM
Is there enough space between the tailstock and the collet to tap a small pipe thread into the side the of the taper? Alternatively just drill a small hole and push in a small tube or make a small hose nipple to press in.
Old 01-18-2009, 08:27 AM
KyleH2's Avatar
Hmm, good question. Right now I am using an MT2 taper in a MT3 sleeve because that's all the American seller had. When I get the MT3 ones from Hong Kong I'll check where it sits in the tail stock.
Old 01-18-2009, 08:16 PM
chenry is on a distinguished road
i would try to keep the adapter sleeve and turn it into a coolant adapter.
you probably dont want to push coolant into the interior of the spindle
if th ecollet chuck has a coolant hole in back you could plug it and add a side hole you can plumb coolant into
Old 01-19-2009, 09:36 AM
KyleH2's Avatar
I'll keep that in mind but I am not drilling through holes so the coolant would go out flutes on to the pan and into the coolant return.
I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control vettespeed Bridgeport and Hardinge Mills 25 05-01-2011 07:50 AM
Problem- sl-30 tailstock travis1 Haas Lathes 0 11-04-2008 11:32 AM
Need Help!- PROGRAMABLE TAILSTOCK raulmees Daewoo/Doosan 4 07-25-2008 08:30 AM
Flood Coolant System for Manual Surface Grinders widgitmaster General Metal Working Machines 10 08-19-2007 02:38 AM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 06:20 PM
