Old 01-14-2009, 08:01 AM
penjas14 is on a distinguished road
Centerdrilling for tailstock
When turning a shaft on a cnc lathe when using a tailstock should you center drill the piece while it is sticking out the amount it is going to be machined, or is it acceptable to chuck close to the end face and center drill it, and the slide it out?
Old 01-14-2009, 08:49 AM
Don't try center drilling with it just sticking out with no support it will flop all over the place and your center hole will not be on center.
Putting it up the spindle so it is held close to the end in the chuck is okay if your chuck is perfectly true or if the entire length will be turned on the OD.
Sometimes the most precise approach is to do the center drilling with the end in a steady rest. This way the end will be running true because the material is being supported on the OD.
Even with the part supported in a steady you can get the hole off center if the center drill starts to wobble as it enters. For really picky work sometimes you may go to the extreme of boring the taper in the center hole with a really tiny tool from the compound slide after you have drilled.
Problem- sl-30 tailstock travis1 Haas Lathes 0 11-04-2008 10:32 AM
Need Help!- Offset Tailstock? SnapB75 General Metal Working Machines 1 10-27-2008 10:22 PM
Tailstock M-Code? gcrudgington Daewoo/Doosan 1 09-28-2007 08:42 AM
tailstock won't extend burnin daylight General CNC (Mill and Lathe) Control Software (NC) 0 03-19-2007 08:54 PM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
