Old 01-13-2009, 04:21 PM
penjas14 is on a distinguished road
Different offsets for different diameters?
If I'm turning a shaft with different diameters, do I need different offsets for each diameter? For example let's say that there is a turn programmed for 1.5 inches dia. and then turned up a shoulder to a 2.0 inch diameter. With a decent machine should I use 2 offsets such as turning with offset 2 and then on my move up the shoulder change to offset 3, in case the one diameter is .004 over and the other is .002 over? This is how the programmer at my shops does it now, but isn't this what resolution and accuracy of cnc machines are all about?
Old 01-13-2009, 05:06 PM
Rafael18 is on a distinguished road
penjas14 I would just change the program not the offset. Having two offsets can get tricky and you can end up making more scrap..
Old 01-13-2009, 05:33 PM
Yea I've thought about that but the challenging part is the skill of our operators. I am using mastercam to program my parts so it wouldn't be a challenge for me but having to have the operators come in and have me change it and then go back out to their machine and load it would be a lot of wasted time. They use multiple offsets now with no problem, but the main problem is that mastercam won't (or atleast noone can tell me how to) generate multiple offsets in the same toolpath. Our current programmer writes them by hand and I am trying to program all of the previously programmed parts in MC. I could edit the program by hand but I'll have to re-edit them everytime I repost the program when i make modifications.
Need Help!- Is there away to drawl Diameters and not radius? Stampede BobCad-Cam 3 06-02-2008 08:04 PM
offsets help please. allmotormatt Haas Lathes 1 03-03-2008 07:36 PM
large diameters sheedy1999 Haas Lathes 29 09-30-2007 06:43 PM
How To Measure Large Diameters? sanjiv Mechanical Calculations/Engineering Design 63 03-14-2007 06:06 PM
Mounted ball bearing for small diameters? Konstantin Linear and Rotary Motion 4 01-31-2007 05:46 PM
