Old 01-13-2009, 04:12 PM
wilson248 is on a distinguished road
Question Unexperienced needs experienced help!!!
New to machining techniques and industry. I am looking for the cheapest and fastest (doesn't everyone) way to cut through 2" x 2" 6061 square tubing. I have been looking at miter saws with a non-ferrous blades, would this be sufficient?. I am so what limited for space right now for larger equipment.
Thanks in advance for all the help!
Old 01-13-2009, 04:33 PM
Miter saw is probably your best bet, running a triple chip blade rated for cutting aluminum; get one with as many teeth as you can and try to get one with the laser cut slits in the blade filled with polyurethane or something to dampen vibration, they make a fantastic difference. Also look for a miter saw with the highest power rating but the lowest blade speed.
It may be a good idea to fabricate something to hold your tube on all sides so it cannot tend to roll or lift. Make a tunnel out of wood that extends either side of the blade so the cut is taking place with the tube supported on each side.
Old 01-13-2009, 04:35 PM
Bubba's Avatar
Bubba is on a distinguished road
the handiest tool I have for something on that order of magnitude is my "Portaband" hand held power saw. That tool comes in handy for whacking off all kinds of material.
Art
EXPERIENCED CNC MACHINIST lbi17 Employment Opportunity 2 12-24-2007 11:37 AM
EXPERIENCED CNC LEAD lbi17 Employment Opportunity 0 12-20-2007 09:22 AM
NEEDED WELDER EXPERIENCED - MIG & TIG lbi17 Employment Opportunity 0 12-20-2007 08:58 AM
Need experienced advise Metalcraft DIY-CNC Router Table Machines 2 02-13-2007 04:22 PM
Advice from you experienced Guyz.. Datum1 Haas Mills 13 06-07-2005 06:04 PM
