Results 1 to 4 of 4
Thread: Help with choices
    Nov 2007
    Help with choices
    I'm looking for some recommendations for some machines I want to purchase. I am looking at getting a smaller size lathe, does not have to be CNC. I would like a benchtop style, as I don't need anything too big. Something in the size range of the Harbor Freight 9x20. That will meet my needs as far as size requirements. Will be turning mostly plastic and aluminum parts.
    The second item is a similar size cnc mill. Again I am not looking for a standard large size machine as both of these machines will be in my basement. This will also be used to machine smaller plastic & aluminum parts. Largest size for this machine might be in the 10"x10" range. Any help would be appreciated.
    Aug 2005
    The 9X20 lathe is a great choice for hobby and limited run production. I have used one in my business for the last 15 years and it has held up. I would not suggest it for 8 hours per day, day in - day out use as it is not designed for that. I was able to carry it to the basement by myself (I was younger then) One thing to note is there are varying grades of this lathe sold; I would pay the extra and buy one from a reputable dealer with good customer support. I got mine from Jet Tools which fills both these criteria.
    Don't know about the mill, but I'm sure someone will chime in.
    Oct 2008
    New Zealand
    Small cnc mill
    The Tormach mill looks fantastic, I'm blown away with how polished their product & documentation seem to be. Unfortunately I needed a machine with over 12" of Y travel, so I purchased a used machining centre instead...
    Maybe one day I'll get one just for kicks.
    Registered Crevice Reamer's Avatar
    Mar 2008
    The lathe that is the most bang for the buck will be the Grizzly G0602 10 x 22.
    http://www.grizzly.com/products/g0602
    Finding a mill that will have 10 inches of Y travel and yet still go down steps is very problematical.
    The very capable Grizzly X3 can be easily modified to have 7-8 inches of Y though:
    http://www.grizzly.com/products/Mill-Drill/G0463
    The above machines weigh 300-400 pounds, but can be disassembled into one-man carriable chunks.
    If you can settle for a smaller mill that will do about 12 x 5 inches and is CNC ready-to-Go, then this $1700 Taig/Gecko is the CNC most bang for the buck:
    http://deepgroove1.com/cncmill.htm
    CR.
  1. New Machine Build- X2 CNC choices
    By sansbury in forum Benchtop Machines
    Last Post: 07-30-2008, 10:23 AM
  2. Choices, Choices
    By Stewbaru in forum Benchtop Machines
    Last Post: 07-09-2008, 04:39 AM
  3. Hold down choices..
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-21-2006, 06:29 PM
  4. So many choices so much to learn
    By cozymkiv in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-03-2006, 07:38 PM
  5. choices, choices
    By zcases in forum Phase Converters and VFD
    Last Post: 04-27-2005, 03:48 PM
