Old 01-12-2009, 02:43 PM
bob1427 is on a distinguished road
Post Alarm code
I need help with a 2000 supermax rebel 1 w/Fanuc O-M control. I get a alarm code 1024 and 1015 when i try to do a tool change the machine is new to us and have no books. the changer moves the pot drops down but the arm does not move. the z is in home pos. and spindle is inline. Any help would be great. thanks
Old 01-12-2009, 03:49 PM
avtechmachine is on a distinguished road
ATC Problem
1. You may need to call G91 G30 Z0; before you call M6
2. Is it a M19 LED on the panel you can see its finish.
3. if the G30 position and the M19 OK then you need to check the pocket up & down proximity switch.
Ahn Vuong
Old 01-13-2009, 05:39 AM
alarm code
I have called out call G91 G30 Z0 and m19 I will have to check the pocket up & down proximity switch and get back to you on that. Thanks for the help Ahn Vuong.
Tags
alarm, cnc, fanuc, tool changer
Need Help!- Alarm code 123 VF-3 Nova Haas Mills 12 06-16-2010 02:48 PM
Need Help!- Alarm code 203-6 meszarosg Okuma 3 10-11-2008 03:17 PM
alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code sting Fanuc 0 01-01-2008 09:03 AM
Mori sl-15 with a new code 100 p/s alarm bob1112 Fanuc 8 07-09-2007 11:32 PM
Alarm Code 3058 AdamK Mazak, Mitsubishi, Mazatrol 2 04-26-2007 10:58 PM
