Old 01-11-2009, 01:32 PM
cogsog is on a distinguished road
Thermal compensation okuma and Mazak
We own several Okuma Mu400VA 5 axis machines. We have reasonable temperature control in our shop in the form of radiant heat in the winter and AC in the summer no doors left open durring any season.no direct sunlight on machines ..target temp is 68F.We find the okuma machines are unreal repeatable from the first part to the last and everyone in between.It looks like Mazak has recently copied the Okuma thermal comp system they are calling it Mazak Intelligent Thermal Shield (ITS).Does anyone have experiance with this new system from Mazak and if so do you find it effective in not having to do the warm up offset dance? This dance simply does not exist on our Okumas even when we are holding crazy tight tolerances.The amount of time it saves us is enormous....
Looking forward to hearing from some Okuma and Mazak users !!!
Old 01-04-2011, 08:29 AM
mktgqueen is on a distinguished road
Glad to know the Okuma thermal compensation is working as it's supposed to! Would you be interested in going "on the record" with your positive statements? If so, please contact us at info@okuma.com.
If you don't want to go "on the record" (statement attributed directly to the source) we understand. Thanks for your consideration.
J. Murphy
Marketing Mgr - Okuma
Thermal Arc PAK 20a scrambled CNC Plasma and Waterjet Machines 1 11-01-2008 09:57 PM
Anyone have a manual for a 250psi Okuma TSC pump for Okuma Mill? Edster Okuma 1 08-28-2008 08:09 AM
Newbie- Looking Fanuc, Mazak and Okuma control manuals kiemkhach Okuma 6 07-02-2008 11:26 AM
Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem sting_dot Mazak, Mitsubishi, Mazatrol 0 05-21-2007 08:20 PM
Okuma OSP5020L Backlash compensation Rocksalt Machine Problems, Solutions , Wireless DNC, serial port 3 02-11-2006 07:13 PM
