Old 11-24-2004, 07:10 PM
tats is on a distinguished road
CNC using xy table
Hello,
This is my first post here so I was a little unsure if this is the right forum to ask. If it's not please forgive me.
I'm trying to create a small CNC to work mainly with copper and perhaps aluminum. After some reading and thanks to CNCZone I figured out that the easiest approach for me will be to use a XY table, or slide table, whatever the right name is.
I was wondering if anyone could help me to find where to purchase it, ebay perhaps? I already found one in a big hardware store here in the city where I live (Curitiba - Brazil) but it costs more than US$500. Which is too high for me.
I thought in the beggining to go for three axis, I already bought 3 stepper motors, but if I have to use just 2, it will be better than nothing.
So any advice to where and maybe even what I should buy would be great. I'm willing to spend around US$100 maybe a little more, I will probably have to add 100% to it because of shipping and importing taxes to Brazil :frown:.
Thanks and sorry for the long post.
_____
TaTs
Old 11-25-2004, 07:29 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
If the table you were looking at was ready for your steppers to bolt onto, you should just buy it.
If it was just a mill/drill type table with sloppy old standard screws and cranks, let it alone.
You didn't mention the XY travels.
Is this what you were looking at?
http://www.kbctools.com/can/PDF/can0454.pdf
This is CDN prices.
www.integratedmechanical.ca
Old 11-25-2004, 09:30 AM
The one I found fits more in the second category you described. I would have to fit the steppers into it. The pdf you pointed is pretty much what I need. As for the XY travel the metal pieces I will work with are not bigger than 2"x3". So I don't really need a big table.
____
TaTs
Need help finalizing plan for CNC Plasma table David Bord CNC Plasma and Waterjet Machines 6 05-25-2005 07:16 PM
CNC Plasma table plans krazycnc CNC Plasma and Waterjet Machines 4 05-05-2005 09:51 PM
CNC Drill driving the milling table Com Vertical Mill, Lathe Project Log 2 04-04-2005 03:27 PM
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 08:23 AM
Cost / Price of a DIY CNC table. Havic DIY-CNC Router Table Machines 10 03-01-2004 02:08 PM
