Old 01-05-2009, 12:48 PM
Michael82 is on a distinguished road
Unhappy Changing the main drive belt on the spindle
I have a Takumi v32n milling machine and the drive belt for the spindle has broke .The only things is that the Machine Tool bulider are not very helpful. I need help changing the belt that goes on the spindle. So does anyone know anything about this machine that can help me? The main problem is getting the belt off and on ,I think I can get the rest of the job after that . It looks like I might have to take the spindle half way apart just to get the belt off. HELP !!!!!!!!!!!!!!!!!
Old 01-06-2009, 08:09 AM
I talked to the tech from the factory and he said that I will have to take the spindle out to get the old belt off and the new one put on. He said that there are two diffrent ways the spindle may be installed . The 1st way is that it is in one peice and after putting blocks of wood underneath jog down the z axis and undo the 8 bolts that go around the spindle then ,when the bolts are loose jog up in z and the spindle will slowly drop out .This is the 1st way, he also said that on some later and larger models the spindle is in many diffrent parts and this he said is the 2nd way the spindle may be installed.It depends on what style and year model ,So I gave him all the info and he should be reponding back soon If anyone has any help please help I have no clue on how to start this job but it sounds like I am on the right track If so any help would be nice THANKS
Remove drive belt on 96 VF-1 w/ TSC/ reset spindle orient bob1112 Haas Mills 6 01-09-2008 07:24 PM
Main current for a drive? (BRU-200) toninlg Servo Motors and Drives 1 06-02-2007 01:27 PM
Belt Drive Spindle Possible? Bird_E Industrial Hobbies (Support forum) 24 11-26-2006 08:44 AM
TL-1, Noisy spindle drive belt DEAN Haas Mills 13 10-30-2006 09:52 AM
Changing the drive v-belt ken65 Bridgeport and Hardinge Mills 2 09-11-2006 10:36 AM
