Old 01-04-2009, 07:32 PM
Fraese is on a distinguished road
Newbie: Knee Mill or Square Column
After a lot of lurking and reading I am close to getting my first own mill. I have worked on standard Bridgeports, some VMC's, and some gigantic production iron for trash can sized parts. Unfortunately, I have no first hand experience with smaller mills and their rigidity.
The mill will be used for hobby projects (some stainless) and would probably be converted to CNC at some later point in time.
In my area I could get a Rockwell knee mill (R8) for about $1400 or pick up the manual IH in CT for $2400. Anything bigger will not fit in my space.
The IH has more dimensional capacity (which I will not need) and is easier to convert to CNC. But how rigid is it compared to the Rockwell knee mill?
Thanks in advance.
Old 01-04-2009, 11:06 PM
TOTALLYRC is on a distinguished road
Thanks in advance.
If you are planning on going cnc in the future, I would look at a used cnc right from the start. You can pick up a used cnc machine for the same $1200 -$1400 and have ball screws and motors and all the little things that don't come with a manual machine when you convert it.
Mike
Old 01-05-2009, 08:41 AM
Mike
Mike,
Thanks for your input. In priciple, you are right but where I live (Boston, MA) small, working VMCs are unobtainium in the price range mentioned. The other issue is that a CNC machine needing work is a large paper weight whereas a manual mill is usefull from the get go.
I am not afraid of messing with ballscrews, motor mounts, wiring, electronics, and software if I ever go CNC. The winters are long here.
However, what is the best hunk of iron to start making chips with: Asian square column (ZAY7045, the larger IH) or small American knee (Clausing, Rockwell, etc.)?
Old 01-05-2009, 11:35 AM
Mike,
I have a preference for a real bridgeport, as I have a manual and a cnc.
I was looking real hard at the IH since I live in CT, but I needed a tool changer fo a lot of the jobs that I do.The extra travel is real nice because you never know when that large job will walk in the door.
The other nice thing with the larger table/greater travel is that you can mount several fixtures on different places on the table and not have to take them off all the time.
I picked up a btc-1 not far from boston and did a retrofit of the controls.
See my build thread
http://www.cnczone.com/forums/showthread.php?t=66994
If your are interested, I am getting ready to sell my J head bridgeport, with R-8 collet set, VFD, SWI DRO and possibly a vise, depending on the final price. I would aslo throw in some cutting tools so you could get started right away.
It has a noise in low range, but it will be fixed before delivery. Worst case is that I have a spare head and would swap it out.
PM me if you are intereted in it. I can deliver it to your place as it will need partial dissassembly to get it out of my shop.
Mike
Old 01-07-2009, 08:43 PM
Mike,
Your offer is tempting but there is no way (none) that the BP will fit in my
10'x20' shop and leave me with enough room to operate it.
I think I will go with the manual Rockwell for now (I can always pass it on for the same money) and get more familiar with what other folks are running as home-brew CNCs.
Your BTC conversion looks impressive. I like the idea of taking a solid machine and replacing the "steam-powered snake pit" with state of the art electronics.
Little has changed mechanically over the years but electronics got a whole lot smaller, powerful, and cheaper.
Thanks for the insight on the DSPMC/IP unit.
Claus
Old 01-07-2009, 09:47 PM
Exclamation Never enough room to play!!!!!!!!!!!!!!!!
Mike,
Claus
I have the Jhead bport, a Tsugami lathe, an atlas th42, Taig mill, bench grinder, and my metal cutting bancsaw, all in a 14' x 14' section of my work shop. It is amazing what you can stuff into a small spacew when you try. I find that the mill set kitty corner works best in a smaller area.
I will be putting the mill up for sale soon, as I need more space as the Tsugami is going to be converted to cnc.
I will be selling the Taig also, along with all the extra stuff I collected, as I am pretty full up with extra's.
Mike
Tags
industrial hobbies, knee mill, rigidity, rockwell
Knee Mill vs Square Column Mill HimyKabibble Bridgeport and Hardinge Mills 0 11-09-2007 06:27 PM
Lathemaster Square Column Mill ? Willyb Benchtop Machines 13 06-01-2007 05:34 PM
Interesting Big square column mill davo727 Benchtop Machines 27 05-13-2007 03:23 PM
Looking for Square Column Mill In Canada? Willyb Benchtop Machines 9 01-14-2006 11:57 AM
HARBOR FREIGHT small round column mill to a square column conversion. motomitch1 Vertical Mill, Lathe Project Log 25 12-01-2005 10:24 AM
