Old 11-23-2004, 06:42 AM
kong is on a distinguished road
Replacement linear bearing seals?
Hi guys, I need some replacement seals for some 40mm ID linear ball bushings I have, but cannot find a supplier. I have tried the "main dealer" in the UK, but they reckon you can't get them Anyone know where I could try? Even if I have to import them it will be worth it. Thanks Jason.
Old 11-23-2004, 07:36 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
First thing I always do is talk direct to the manufacturer. That usually provides the desired results (and saves me a lot of money).
I would also think a replacement bearing insert would be about $60.
www.integratedmechanical.ca
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 06:10 PM
gas pipe & linear bearing dimensions relationship zoltan Linear and Rotary Motion 6 06-13-2005 03:12 PM
a cheap linear bearing mocnc DIY-CNC Router Table Machines 8 03-26-2005 04:52 PM
Linear bearing spacing & Sizing linear rails? fyffe555 DIY-CNC Router Table Machines 3 12-07-2004 01:09 PM
What is a linear bearing ? ynneb FAQ of CNC Machine building 0 08-16-2004 09:34 PM
