Old 01-04-2009, 10:31 AM
sharpshooter90 is on a distinguished road
DEFINE REPEATABILITY ?
I have seen a lot of posts in which people ask about a machine's "repeatability" I have a moderate amount of machining experience, but frankly that issue eludes me. If you are talking about a CNC machine, I would guess that repeatability would be the accuracy of a batch of parts produced by the same program. Even though tool wear could make certain variations beyond the machine itself. But for us guys running the machines manually, how would you measure repeatability? Even a simple operation requires a few inputs from the operator, so how would one distinguish between machine error and operator error?
Old 01-04-2009, 12:37 PM
hover1's Avatar
hover1 is on a distinguished road
I think I can answer this. In short, repeatability is the ability to return to the exact spot that was commanded before. At least that how it was back in the 80's when I worked for Gerber on the Photolotters, you know...Gerber.."G" code.
Jim
Old 01-04-2009, 01:29 PM
REPEATABILITY is the same as PRECISION; that is how close to you approach any position.
ACCURACY is how close is a distance to the true distance a machine moves.
For instance if you command a machine to do a homing operation and find machine zero it will stop at X0., Y0., Z0.; but not exactly there there will be some variation each time the homing is done so machine zero fluctuates by the precision of the machine. On commercial machines this will be +/-0.0001" sometimes better but then you have to starting getting worried about keeping temperatures constant.
Once you have machine zero you can command the machine to move 10.0000" on the X axis so it will go to that position with the same precision, +/-0.0001".
Because the starting point (machine zero) had a precision of +/-0.0001" and the finish point has the same precision the ACCURACY of the move is no better than +/-0.0002"; it could be worse because the precision to which the ballscrew is manufactured also comes into the picture but on commercial machines this could be better than 0.0001" and also sometimes the screws are mapped and a correction table established for accuracy.
On CNC machines the rotation of the ballscrew measured by encoders while on manual machines it is the operator squinting at the little graduations on the handwheel (when a DRO is not fitted). This just means the precision is going to be +/-0.0005" or maybe much worse, while again the accuracy depends on the quality of the screws as well as the operator precision.
Old 01-04-2009, 09:05 PM
hover1's Avatar
Geof,
Thanks Geof, I understand the response, but I was just trying to give sharkshooter90 a general definition. I didn't think he wanted to be overwelmed with too much information at this time.
More in depth info at Google book search "machine tool repeatability"
Old 01-05-2009, 06:00 PM
Thanks guys-
I think the term really has no meaning unless you are running CNC. Obviously on a manual machine the operator skill will determine the results far more than the machine, maybe with the exception of some of those old specialized machines that ran repeated operations from a set of cams.
Best CNC accuracy and repeatability? DeepWoods Benchtop Machines 5 08-29-2008 02:04 PM
Need Help!- Y Axis Repeatability timprebleco Bridgeport and Hardinge Mills 3 08-28-2008 10:52 PM
Build Thread- How I tested my Y for repeatability IQChallenged CNC Wood Router Project Log 3 05-11-2008 07:41 PM
MC9-Define Plane menu. Where is it? neilw20 Mastercam 14 05-09-2008 10:41 AM
Please define our hobby - Stepper Monkey Benchtop Machines 36 07-09-2007 07:32 PM
