Old 01-04-2009, 09:37 AM
*Registered User*
jho5820705 is on a distinguished road
Question about Lathe/Milling Spindles
I am trying to learn more about the machines I bought and have been using for several years now. My question is: How do i increase the accuracy of the machines. I know ball screws will help, but what can I do about run out at the spindle. My lathe is OK, but I can't seem to get that last few tenths of accuracy that I would like to have. The same is probably true of the milling machine but I haven't noticed it there because I don't usually require better than 2 or 3 thousandths. Can I change the spindle or bearings and increase accuracy? I have a small Grizzley 6X36 that I bought 5 years ago so I really don't expect great accuracy, but would like repeatablity better than a couple of thousandths that I am getting now. Any suggestions or information about spindles and how to make them more accurate would be appreciated.
Old 01-04-2009, 10:34 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Here's a method for testing and truing the chuck:
http://www.varmintal.com/alath.htm#Truing
CR.
Old 01-04-2009, 11:16 AM
*Registered User*
I will have to give that a try. I don't have a tool post grinder but can rig my electric die grinder to do the job. Just wish I knew more about spindles and how they relate to accuracy in general. I feel like I am working in the dark when I work on the machines.
Old 01-04-2009, 12:42 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Here is some info on tuning up your lathe spindle:
http://www.arceurotrade.co.uk/projec...ges/index.html
It may not be quite perfect in every detail given your type of lathe, but it gives you some idea where to start. Rumor has it that upgrading to SKF bearings and following these procedures makes a noticeable difference.
Best,
BW
Old 01-04-2009, 01:35 PM
*Registered User*
Thanks BW,
The bearings could be part of the problem. Might explain some of the chatter I get with the cutter when machining steel. Guess I will have to try to cross the current bearings with SKF and see if I can find a better replacement. Wish I knew more of the theory behind spindles and how they are designed, it might make it easier to understand what each of these changes accomplish.
CNC MILLING MACHINE VS CNC LATHE timbot1982 Machine Created Art 5 11-14-2010 12:08 PM
Newbie question- Why fast spindles in Al? Shepard General Metal Working Machines 3 01-04-2009 02:03 PM
Need Help!- thread milling on lathe Bigbill Mastercam 2 04-10-2008 12:06 PM
Lathe question: Thread milling vs. single pointing.... PoiToi General Metal Working Machines 0 02-21-2008 07:24 PM
Questions about milling spindles Hack General Metal Working Machines 13 01-27-2005 04:42 PM
