Old 12-29-2008, 02:43 PM
EddieO is on a distinguished road
Deciding on a Mill, Haas MiniMill or Sharp 2412
Ok, this is going to be a long winded post.....lots of newbie questions and a fairly straight forward request about responses.
The request on responses is simple.....please just answer the questions, don't attempt to tell me I am getting in over my head or that I am wasting money or the what not. There is a bunch personally that I am not going to talk about that factors in the decisions I am making.
So, with that being said, I have decided to start a machine shop out of my garage, mainly to support my side business of RC Car parts that I have been running for 5 years now and am going to be doing it full time now. My business mainly did motors and batteries, along with the occasional specialty part or tool. Motors and Batteries have changed a bunch, since the acceptance of Brushless and Lipo batteries, so to keep my company going, I am going to be moving in new directions with machined parts, while still doing the motor and battery thing. I will also be machining some Airsoft gun parts (not very big) and possibly the occasional small car or bike part for my dad/brother. Nothing will be very big, say bigger than a shoe....
I am a very big novice at machining, but I am well on my way and eager to learn. Ordered quite a few videos and books, along with working on setting up a mentor thing local. I am going to be buying a few mills, but I want to get my workhouse out of the way now, while I am able to make it happen.
I have narrowed my choices down to the Sharp 2412 or the Haas Minimill.....
Now the problems I face are the following.....
Since the unit will be going in my garage at home, which is attached to the house, I have a few size and power issues.
First, my garage door, if I take it off the hinges and everything MIGHT squeek at 84 inches, probably more like 83...once inside, I have 112 and techincally, I could cutout some drywall if I need a few more. I have tried finding the minimum hieght specs on both machines, with little luck. I have a sturdy 4 inch floor from what I can tell.
Second, is power....I am not a power expert, but from my understanding, 3 phase is not very doable for a reasonable price in residential neighborhoods. I am already gonna have to upgrade my box, as I am out of circuits anyways. I don't really understand the whole phase convertor thing, tried reading about it on the net, but the info is very generic.
Now on to the machines......seems like a toss up really. Some people seem really sold on the haas, but the limited few posting on the sharp think they are amazing...
The pros/cons
Haas
Pros
Well Built
Solid rep
small foot print
single phase power requirement
Cons
tech/repair seems to have issues in certain areas
might be too tall
guides are not as good sharp from what I read
sharp
cheaper
better guides
seems like better customer service, regardless of where u live
cheaper
bigger work space
from what I read, its shorter max height
cons
3 phase power (oof)
less info on the net about them
Other questions I have is about accessories and software. Which do I need and what comes with the unit? Any ideas what I would be looking at price wise out the door? I worry about calling the companies, cause they are just gonna tell me what I wanna hear and then find out its not.
I have attached photos of items similar to what I would be machining for RC parts.....Airsoft stuff is basically internal parts for the guns, very small....
Just to be clear again, my situation sets me in buying this machine. I am in the process of buying a couple of other units.....a smaller CNC for prototyping and a manual mill for whatever, mainly just to learn and stuff on or even a prototype...
Thanks for looking and any help you can provide, keeping my RC company going is keeping my dream alive.....
Later EddieO
ID:	72479   Click image for larger version
ID:	72480   Click image for larger version
ID:	72481   Click image for larger version
Old 12-29-2008, 03:28 PM
ckirchen is on a distinguished road
I fit my MiniMill under an 83.5" door frame; though I had to loosen the clamp for the cable loom and fold it down to the side. Once inside, the ceiling is 96", so I had to cut a hole above the machine for the loom. In use, the top of the head has 1" or 2" of clearance.
A rotary phase convertor is pretty easy to set up, so don't make that a deciding factor. But don't forget to include the cost of the RPC when comparing the two.
The MiniMill has linear guides and the Sharp has boxways. Linear guides use recirculating balls with zero clearance and boxways have multiple sliding surfaces with a minute clearance. I've read that linear guides are better suited for speed and accuracy, whereas boxways are better for heavy loads.
The higher maximinum spindle speed on the Sharp might be nice to have (8000 rpm vs 6000 rpm on the MiniMill).
Chris Kirchen
Old 12-29-2008, 03:38 PM
little bubba is on a distinguished road
Thats an awful lot of words for asking a simple question.
Since you asked not to tell you not to do it, I won't. However the one thing you didn't answer in your ramblings (I ramble too) is why you narrowed your choices to Haas or Sharp? And also why you have decided on new (guessing here from your post) not used.
The question I think you needed to ask was "what machines should I consider". I don't think you would be disappointed with either the Haas or the Sharp (I'm not a Haas fan, the salesman never brings beer, but they can certainly make money). I think you would be happier with the Sharp over the mini-mill though, to me it seems like a lot more machine for the money.
Other machines I would consider, are the bridgeport (hardingequotes.com to get a price and options list), Fryer, Kent has some small enclosed VMCs that look nice (a guy up the street has one). A PM member that recently passed away bought a Litz Hi-tech (mitty??). He shoehorned it into a garage and it was a whole lot of machine for the money, somebody else bought one over there too and they both seemed very very happy with them, I'd never heard of them, but it seemed a lot of bang for the buck.
Phase converters, they really are easy, 2 lines in, 3 lines out, and make sure you ground it good. If you don't foresee 3 phase in the near future, don't go cheap, buy quality(ask me how I know). A lot of people love the phase perfects.
As for the other stuff you need, like what???? Tool holders, Maritool is fantastic money spent, good quality, fantastic prices and a small American business. Vises, shop around. Software, unfortunately you are going to actually have to talk to people, if you are worried about or think you are getting the run around tell them to go screw. You're a business man now, you have the money, you're in control.
Good luck, its a wild ride, but well worth it.
Old 12-29-2008, 04:03 PM
I am certainly not opposed to looking at other machines. Haas is a name I kept hearing, so I started reading.....read a lot of good stuff about the minimill, but then I stumbled on the Sharp while reading about the Haas...seemed to be a similar unit in my price range that could do the work I wanted....
There seems to be a LOT of stuff out there to buy, so it gets confusing......I will go check out those other brands, see what they got.
I am not totally opposed to used.....but, on something so pricey.....I would rather know it was my POS from the start, not someone elses headache that I bought. Seems the availability of the minimill or sharp used in my area is limited too....
Thanks for the info so far....
Later EddieO
Old 12-29-2008, 04:31 PM
vlmarshall's Avatar
vlmarshall is on a distinguished road
Have you seen the Haas 'office mills'? They're even smaller than a minimill. I don't have any experience with anything smaller than the VF-3s, which I've used for 13 or 14 years now. Great machines.
Good luck with your business, I'm an RC fan, myself.
Old 12-29-2008, 04:37 PM
I checked out the office mill.....and pretty much everything I read, says if you can fit the minimill, don't get the office mill.
I am gonna call haas and sharp tomorrow, see if I can setup a demo or something....or find someone local with one.
Later EddieO
Old 12-29-2008, 06:57 PM
Originally Posted by EddieO View Post
.. if you can fit the minimill,....
And if you can fit the MiniMill get a SuperMiniMill.
More money and you will need a rotary phase convertor because it needs 3 phase.
10,000rpm spindle.
Almost double the rapid speed; 1000 versus 650
Much faster tool changer; the shuttle moves in quicker and the carousel indexes faster, tool changes take about 1/3 the time of a standard MiniMill.
Old 12-29-2008, 09:20 PM
Gold Member
jdelaney44 is on a distinguished road
Briefly -
Check out used machines, too many great deals on great machines out there now not too.
Lot's of people do fine on phase converters, agree, not a factor.
Lots of machines get taken apart and put back together for a move. It's just a matter of $$$. A couple hours of a mechanics time is probably cheaper than tearing up your garage.
You should absolutley get a demo or have the dealer arrange a site visit to a referenceable client. This is a huge investment. Well, it would be for me.
Drive a bargain. People want to sell. Use that in your favor. Should not slow you down much.
Sorry, don't know crap about either machine.
Good luck, happy hunting.
Best,
John
John Delaney
www.rwicooking.com
Old 12-30-2008, 06:58 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Considering you appear to be doing all aluminum work with mostly small diameter cutters. Spindle speed will be one of the most important factors for parts production.
EG a 3/16 aluminator cutter wants to run at over 10,000 for ideal cutting which brings your IPM way up and your cycle time way down.
www.integratedmechanical.ca
Old 12-30-2008, 07:39 AM
JDenyer232 is on a distinguished road
I believe the Sharps use the Fanuc oi-mc control, which is what we have on our Fanuc Robodrill, a very user friendly and solid control. With that said we just got an SL10 lathe and man the control on that is really nice, for one it's a 15" lcd, and you can buy IPS as an option to machine simple parts. For the more complex stuff we use Sheetcam, a very inexpensive and versatile Cam program. Looks like you do a lot of 3D stuff so you might want to invest in a good 3D cam software package. Of the 2 controls I prefer the Hass, for one the screen is much larger and easier on my old eyes, and two I like the fact that most functions are just a button push away, with the Fanuc you have to scroll through menus with softkeys, not bad once you get used to it, but once you try a Hass control you can really see the difference in ease of use. If it were me I would go with the Hass SuperMiniMill. Especially if I were doing aluminum, your gonna want that 10k spindle, trust me. You should also budget in a laptop and DNC software if you are gonna be running complex 3D stuff, the laptop doesn't need to be new, an older one running 98 or XP is fine, just make sure it has a 9 pin serial port. If price is a concern then look around in the used machine market, there maybe some hobbyist that bought one of these and now needs to sell, now is a great time to look into the used market. Hope this helps.
  #11   Ban this user!
Old 12-30-2008, 02:51 PM
LUCKY13 is on a distinguished road
I agree with Geof. It looks like you will mostly be working with aluminum and the super is going to trump the other two hands down.
IMHO if you can afford to talk any of these machines, you can't afford not to get all you can get for a machine. But do look at the big picture, tooling, software and assy will all play a part. I think if your going to be doing things like the wheels you will need a 4th axis also.
There are some good deals out there on used equipment, but I think in your possition it is a safer & more productive route to go with the new (if the Haus guy doesn't bring beer, stock your own it will be your brand anyway then). Out of all of these machines (encluding the super Geof meantioned) I would let budget, spindle RPM and fitting in your garage point the way. The spindle RPM will be your number one indictor of performance with these machines. And you really can't go wrong with any of them. And yea don't worry about 3 phase, but do have good wiring to feed your new phase convertor, or machine, which ever way it goes. BTW, small aluminum parts, high speed is the key.
The small & manual machines you meantioned are a smart idea. You might even look into a small CNC decktop mill (something like a Taig or X4 even or better yet a Tormach)and use it for awail before you even buy your big machine. Getting your feet wet will teach you alot about what you will need. It will also save you some money in the long run when you crash your cheaper mill learning instead of your new expeincive mill. You get the right desktop mill I don't thing you will need a manual mill. Also a good desktop lathe will go a long way in complimenting all these machines.
Really the more I think about it the Tormach mill can handle the manual needs, plus a good CNC prototyping machine, and you can get a Duality lathe to go with it. You can use any of these CNC machines in a manual way with a simple hand held pendant, so I would not put any resources into a manual machine. The Tormach package would make a great starter,prototyper, manual, lathe, doall kinda machine that has great service and proven performance with good quality for its price range. It will be there years down the road working right beside your new big machine. There is a section in this forum on the Tormach. You can also get some nice software packages with it that will help on the other machine. Of course this all depends on what you where going to spend on second machines, but it would be worth looking into the Tormach for these needs. Heck, depending on your production rate you might find you don't need anything else.
As far as Haas vs Sharp, don't worry with it, get the machine that fits the need best. The Brands are good, the specs are what to look for (spindle RPM, table trave, spindle to table distance, rapid speeds, fit the garage, tooling cost, is there local service, etc,etc,etc.....)
Jess
  #12   Ban this user!
Old 12-30-2008, 03:41 PM
Thanks for the posts.....I have been getting tons of good info and doing lots of research.
For the smaller cnc, I have been looking at the mikini mech unit being offered for a great price and the customer service so far from them has been top notch in answering my questions and such. I like the fact its full enclosed and such, with a very small foot print and excellent specs.
For lathes, I have a smaller emco I bought for my RC motors and really never used much, till the end, when we developed a ring that went around the comm tabs to prevent them from blowing apart at high RPM. We had to turn the arms down a little at the tabs for them to fit on.
I also have a large older monarch (I think). I never used it, bought it auction for the rc stuff, then was told it was way to big for what I was doing with the motors. I got it at an auction for $500 and it came with a bunch of collets and other stuff (like 3 boxes worth). I have not looked at in years, as it just sits in the back of my dads store. I plan to bring it over and use it if possible, along with the emco.
I talked to a couple of the companies who make the wheels already, they all do them on a 3 axis unit from my understanding.
For software at this point, I am looking at Mach3, OneCnC and Rhino3d.....all seem to have good support and followings, while being reasonably priced. I heard they like to bargin with the onecnc, and I love to bargin.
I was able to look more into the 3 phase convertors.....seems the pricing varies, especially as you go up in power. Anyone know what size I need for the supermini or minimill?
Thanks again for all the help....
Later EddieO
Sharp CNC V 2412 Question pshsguy18 Sharp CNC 21 01-22-2010 09:15 PM
Servo noise on a sharp 2412? longcut Sharp CNC 5 10-06-2008 09:03 AM
Problem- sharp sv-2412 tvolsch Sharp CNC 7 03-08-2008 11:21 AM
Sharp SV- 2412 CNC Machine Question pshsguy18 General Metal Working Machines 3 02-15-2008 11:35 PM
Sharp SV-2412 Larry B. CNC Machining Centers 18 10-12-2007 08:58 AM
