Old 11-20-2004, 12:37 PM
studysession is on a distinguished road
Using CNC Mill for Engraving
Hi -
I have a CNC Mill and been engraving with it using DeskEngrave. Problem is I do not have good bits for engraving. Anyone have any suggestion on what would be good engraving bits to use for doing small letters and pictures?
Links would be appreciated -
Many thanks!
Please check out my CNC blog
http://cncinside.com
Old 11-20-2004, 04:58 PM
FatChips is on a distinguished road
I use 3/64-1/16" Ball Endmills, they work great for me.
Old 11-20-2004, 05:01 PM
Cool - Thanks!
Old 11-20-2004, 05:02 PM
What about for small letters no bigger than 10mm in height???
Old 11-20-2004, 05:43 PM
Gold Member
JFettig is on a distinguished road
That is what I have used for about 1/2" letters, 1/16" ball mill.
Jon
Old 11-20-2004, 06:13 PM
Thanks - I have been having a lot of fun engraving. But now I want to get some real detail. That is why I am posting. The engraving is getting smaller and smaller.
I found the company that sold me my mill carries bits for engraving. Looking like good prices too. I am going to call them this coming week. Does anyone else use DeskEngrave?
Old 11-22-2004, 08:42 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I would be inclined to buy specific engraving tools if you do a lot.
FIY I do a bit of part number engraving (in metal) and I just use a #2 centre drill.
www.integratedmechanical.ca
Old 11-22-2004, 01:32 PM
Have any links to places that sell engraving bits?
Old 11-22-2004, 02:51 PM
Swami is on a distinguished road
wow, I didn't even think of that. I have some small center-drills. They are super-stiff, and probably run truer than the Dremel bits I have been using.
The best thing I've used so far (and that is not saying much) was a very sharp conical Dremel bit. You can set how wide you want the cut by adjusting the depth.
Swami
Old 11-24-2004, 02:20 PM
JIMMY's Avatar
Moderator
JIMMY is on a distinguished road
I Use .015 Dia. Ball Em. I Cut Letters That Are About .05 Ht.
  #11   Ban this user!
Old 11-24-2004, 02:27 PM
Here is one place online, but you need a $25 minimum order.
I just got a .015 cutter off ebay for a better deal. I figured .015 would be perfect for this engraving I am doing. .015 is way thinner than a mechanical pencil.
When I run the Gocde through CutViewer (simulator) it looks like crap unless I use a .005 cutter. The details get all cut overtop of each other.
Wouldn't you think a .015 cutter would work well on a drawing that looks great using a .5mm pencil?
Swami
Old 11-24-2004, 02:56 PM
DareBee's Avatar
Swami
Yes it should.
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 12:06 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 04:07 PM
Which CNC Mill and what software? MaxxMan-X Knee Vertical Mills 16 04-18-2004 11:25 AM
Need to CNC my mill quickly - advise? SRT Mike General Metal Working Machines 3 03-15-2004 12:10 PM
