Old 11-20-2004, 09:14 AM
Swede's Avatar
Swede is on a distinguished road
Ground Ballscrew - No nut!
Another ebay purchase - this item was an extremely high-quality linear motion device by NSK called a monocarrier. It combined a ballscrew, ground steel guides and plate, and the truck was combined with the ballnut.
I bought it knowing that the truck/nut was missing, as the fixed and simple support ends for the ballscrew were alone worth far in excess of what I paid for the whole assembly.
Now that it's apart, I have a deluxe 12mm ID dual BB fixed end ready to go on another project, a nice steel simple end, and the prettiest 16mm/5 pitch C1 ground ballscrew you'd ever imagine - but no ball nut.
What the heck can I do with a ground screw and no nut? Can it be refitted with another?
Old 11-20-2004, 09:46 AM
trubleshtr is on a distinguished road
Hi swede, I don't see why you can't use another nut, Usually when ball screw systems are designed the nut is the wear item that is replaced, You would think that NSk holds their tolerances when fabricating thousands of these things and that a replacement nut would be able to fit any mono carrier of the same model type?
check NSK's web site
http://www.ca.nsk.com
good luck
Old 11-20-2004, 11:05 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Swede,
That was the same question I had....could a nut be obtained for an existing ballscrew that will properly "merge" ?
I saw that item and contemplated placing a bid but for the missing truck/nut. I found another 20" 3/4"ballscrew/nut at rediculously low cost with end mounting blocks, nut mount, thrust bearings, pulley,etc. In fact, I got two using "buy it now". One came caked in hard grease and did not meet the advertised specs (balls had not been circulating). So a call to the sellor was made and they promptly sent out another at no extra cost. Now I have Three units, two of which are in excellent shape with very low backlash, and the third for more parts.
Trubleshtr adds a vote of confidence!
Bloy
Old 11-20-2004, 11:48 AM
Swede's Avatar
Thanks guys, What you both say makes sense. I don't think the nuts are hand fitted - I think the screws come from the grinder made to a tolerance that allows stock nuts to be mounted. I'll check NSK. It'll probably be one of those deals where the nut costs $250 to be fitted to a $30 eBay buy.
Oh well, the bearing blocks were worth the $$.
Old 11-20-2004, 02:42 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Bloy,
What was the name of the vendor, I'm in the market for a ball for a 20 mm ball screw
NSK 2020A6.
Hager
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
How to model a ballscrew and nut and simulate motion CNCnUtZ Solidworks 15 01-31-2011 08:12 PM
Motor supply ground vs Logic ground? Gashmore General Electronics Discussion 11 06-07-2005 05:21 PM
BALLSCREW nut threads? Trapper14 Linear and Rotary Motion 6 04-13-2005 12:49 PM
So I got this new cool ballscrew... Noah General Metal Working Machines 5 03-20-2004 03:50 AM
