Old 12-22-2008, 08:44 PM
Tony(BDE) is on a distinguished road
Need Help with rigid Tapping
Can anyone HELP with Rigid Tapping on a Matsuura mill MV-500. I don't have a tapmatic holder for a 7/8-20 Tap, so I need to put the tap in a regular endmill holder.
I know the standard G84 code will not work. G63 and G64 will not activate rigid Tap, dose anyone know if I have to change a parameter??
Tony
Old 12-23-2008, 11:15 AM
stevo1 is on a distinguished road
I am not sure about your machine. Do you have a list of codes for your machine? On some machines that I have worked on (mainly Fanuc) you have to use a M29 to active rigid tap or there is a G84.2
Stevo
Old 12-23-2008, 03:24 PM
CNC Viking's Avatar
CNC Viking is on a distinguished road
Also check if the spindle or the spindle motor has an encoder which is needed to synchronize the rotation with feed so you get x mm Z-feed per rev.
Old 12-23-2008, 09:01 PM
SumDumPhuckr is on a distinguished road
From what I remember on the Matsuura that I ran it was a G93 to turn the Mode ON for tapping.
e.g.
G43 H6 Z1.0
G93 (Mode ON)
G98 G84 Z-1.0 R0.1 F0.0625 S800
X0 Y0
G94 (Mode OFF)
G28 G91 G80 Z0. M29
Old 12-26-2008, 01:17 PM
Thank You All for your help, I have tried G94,M29 & M28, G61,G63,G64, and Nothing.
I have been Machining for over 20 Years, I have Programed Fanuc,Mazak, Okuma,Bridgport,Haas,and Now Matsuura with a Yasnac Control. I Have not giving up on this I will find out if this Machine will Rigid Tap, It is an older machine, 1986, and we just recived a Matsuur a mill with 5 axis capability, so I better get it Again thank you all for your help so far, please keep it comming.
Tony
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
Tapping head or rigid tapping Gregory_C Syil Products 2 10-18-2008 12:49 AM
Need Help!- Rigid tapping TL 1 Peter Gibbs Haas Lathes 7 09-06-2008 06:04 PM
Rigid tapping 0-80?? SIERRAMACHINE Fadal 2 01-16-2007 11:21 AM
Rigid tapping or tapping head wildcat Industrial Hobbies (Support forum) 7 09-24-2006 12:08 PM
