Old 12-20-2008, 01:22 PM
mbpp is on a distinguished road
Condensation Problems
I have 4 CNC Machines in my shop. The shop is a single block construction and not at all air tight. The problem I have is that the moisture in the air is condensing on any metal and any cold surfaces. The machine beds and chucks etc. are covered with a layer of water. Raw material etc. I'm more worried about the machine electronics. I have reciently had some problems with one of the machines and I've replaced the control cards a few times, which is expensive. I'm thinking about buying a large dehumidifier and leaving it going 24/7 one with some kind of humidistat (or whatever it's called). What I'm wondering is, would this be a complete waste of time if the shop is not air tight ? would I be better off putting light bulbs in the electrical cabinets of each machine ? or is there another solution ?
Thanks in advance guys.
Old 12-20-2008, 01:38 PM
If there is a lot of air flow through the building a dehumidifier will probably not work because it will be trying remove too much moisture.
Keeping the machine cabinets warm as you suggest with a small bulb or heater will probably work to prevent condensation here.
It is really difficult to prevent condensation on the machine surfaces in an unheated space that is not air tight. Try making it more airtight so a small heater can keep the inside temperature a bit above what it is outside will go a long way to solving the problem. My home shop is in a converted barn and until I had insulated it and put in vapor barrier it was real problem keeping the humidity down inside. Now I use a wood pellet stove and just keep it a bit warmer than the outside temperatures and everything is fine.
Old 12-21-2008, 09:50 AM
bigbaz is on a distinguished road
Condensation
What are you using to heat the building, if its a gas jet heater your filling the building with condensation from the gas.
Old 12-22-2008, 07:31 PM
cheers guys,
I guess I should work on the airtightness a bit. I use an electric heater to heat the place a bit. It's got a lot of elements that heat up and a fan behind them that blow the hot air out. Up until 2 years ago I had a diesel blow heater but someone told me that it was putting out a lot of moisture so I got rid of it and got the electric one. I'm going to try and insulate it a bit and get a dehumidifier. I'm really sick of looking at the condensation, at this time of year in particular.
5t problems markjb Fanuc 16 11-30-2011 11:36 PM
Arc problems nda22 Mach Lathe 2 07-03-2007 07:19 AM
problems? steveo Mastercam 5 08-17-2006 12:59 PM
More problems Cold Fusion Gecko Drives 8 09-09-2005 01:19 AM
85 vmc 40 problems tractdesign Fadal 0 01-17-2005 04:15 PM
